Thu, Jan 30, 7:19 PM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Dec 04 2:47 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: Help!!!
LilGibby ( ) posted Sun, 20 July 2003 at 2:52 AM · edited Thu, 30 January 2025 at 3:38 PM
The window where the figure is, the one that you see in the middle of the page, is not where it use to be. I dl'd a few new objects and mats and the next thing I know is when I open poser it has the window with the figure at the left top corner of the screen and I can't figure out how to get it back to the middle of the screen, it is covering my camera and light buttons, also half of my rotating buttons....please help.....I have poser 4 with the pro pak..... :(
shazz501 ( ) posted Sun, 20 July 2003 at 4:47 AM
not sure if 4 is the same as 5 (i hope so) but this is how to do it in 5,if you look just above the top left corner of the window where it says either untitled or the name of the file opened,click there with your mouse and drag the window back to the centre of the interface,i hope this helps
Ericroy ( ) posted Wed, 23 July 2003 at 10:19 AM
If the title of the document window is off the screen, you will need to set Poser to the factory default settings: 1. Go to Edit>General Preferences... 2. Under Document Preference, select Launch to Factory State 3. Under Interface Preference, select Use Factory State 4. Select the Set Preferred State button 5. Select the OK button. I hope this helps, Ericroy
LilGibby ( ) posted Wed, 23 July 2003 at 3:43 PM
Thank you! The last one worked.... yayyyy, now I can start a new picture :)
