Wed, Dec 25, 7:09 PM CST
Subject: Adding additional terrain
3-DArena ( ) posted Fri, 25 July 2003 at 10:06 AM ยท edited Wed, 25 December 2024 at 7:13 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=453931
I finished this image http://www.renderosity.com/viewed.ez?galleryid=453931 the other day - trying to get comfortable with VUE4 as I've previously only used 2 and only briefly. One of the comments suggested a sandy terrain, which I agree that it needs. I tried to (see the sand in the front) but I couldn't get it to show up without overtaking the trees. Syhould I have made it flatter? I gave it a bit of swelling and it took some manuevering to get that little bit of sand. Suggestions on building up extra terrains?
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use.
-Galileo
SAMS3D ( ) posted Fri, 25 July 2003 at 10:37 AM
I wouldn't change it at all, I love this image, great great work. Sharen
nish ( ) posted Fri, 25 July 2003 at 10:42 AM
If you add the sandy terrains in front of the tree line and then move the camera slightly up and then face it slightly downward, that should do it. Obviously the terrains should be flattened, cuz they are almost the same as sea level. And from terrain editor make your terrains 512*512, for better resolution. Someone else might have a better suggestion. Regards. P.S. Great work by the way, specially for second image.
3-DArena ( ) posted Fri, 25 July 2003 at 10:46 AM
Ah I didn't think to angle my camera up and downward. Thanks sharon but I was a bit annoyed to see that I hadn't saved it with the other rock texture - I preferred the smooth mossy one. It freezes on me though sometimes and I have to close it out and re-open it to finish and that's what happened with the rock.
-Galileo
gebe ( ) posted Fri, 25 July 2003 at 10:51 AM
and... do NOT use Vue's faked forest. It only looks natural when seen from very far. Use "real" trees:-) Guitta
