What Jim said. These error messages indicate a lack of thought on the part of some merchants. Anyone selling a product should always ensure that it will work in all versions of poser. And the easiest way to do that is use the lowest common denominator, which is poser 4. In fact, DAZ insist that version numbers should be no higher than 4.0 for brokered products. It's a small thing, but as you've no doubt found, quite annoying. As for Freestuff.... well, it's free, so I suppose we shouldn't be too ungrateful. mac
It also might be that you have never installed any patches to Poser 4. The version numbers in files are usually quite specific and someone with a patched Poser 4 will generate files that show a later version. It is recommended that all Poser 4 users install the patch. It's available at curios labs site.
**I've been using Poser 4 without the pro pack and every time i try to load a morph into my V3 a box comes up with an error of "newer version number than expected" about six times before it loads, will the pro pack stop that or am i going to have to re-install Poser?
Thank You
HAE Inc.**
