Looks good but a lot of packages have obj imports that will take a static Poser 4 scene up to a point and render it. Bryce does this. The problem is the amount of fix up one has to do on materials especially if you are using 5 nodes. I went to the amazonescity site (my kind of site btw :) but couldn't find the plugin. Does it import a straight pz3 file and render without adjustments or do you have to go and tweak materials etc? Carrara supposedly imports poser but upon talking to their rep at comicon its just an obj file import. What is needed is a better renderer that also allows figure posing in the app. That would be perfect. Vue imports pz3 files but I don't think it handles the nodes. I use a lot of material nodes now making exporting rather tough.
Attached Link: http://www.amazonescity.com/download/free3dformembers/index.php
i found it ok ... but it is in French i thinkAttached Link: http://forums.mec4d.com/viewforum.php?f=36
Nicky has a forum at Mec4D.com! She helps always when a user has questions :) Mazak BTW I am gladly someone love my picture :)I just started playing with it today.. takes about 2 minutes to set up your figure with the plugin... step#1 export wavefront object step#2 save figure with clothes etc... as a cr2.. in poser step#3 open cinema step#4 load object step$5 run plugin.. step #6 load saved cr2 from before (or a pose mat file) step #7 build mat's (just press on key in plugin)... does the transpancy,bumps,etc..) step#8 render (full screen) no tweaking needed.. step #9 snag it (screen capture)
Attached Link: http://athens.ict.usc.edu/Probes/
Yes It's HDRI... I use one of the light probes from: http://athens.ict.usc.edu/Probes/ (Uffizi Gallery Probe) MazakThe scene has no 'lights' The light and shadows are created by the HDRI map. The HDRI texture is mapped to a 'Sky-Object'. And another important setting is to deactivate 'lightautomatic' in render setting. I use German C4D I hope it's translated correct. Mazak p.s. stewer Bei fragen IM an mich ;-)
Attached Link: http://www.rain.org/~msavard/hdri/Articles/UsingHDRIs.html
Link for a HDRI tutorial... Mazakthey work if you move them to the correct channel in the materials manager.
@ mondoxjake: C4D has an option to render in a picture-manager (Bild-Manager). You can render the picture as big as you wish! Move in this manager the sliders, make your screenshots and compose the cropped image in a paint program. I hope this work for the Demo version. Mazak
mondoxjake: render resolution.. it reallity at it really means is you're increasing the size of the image.. (it's really only usefull for prinitng).. becuase when u look at somethimg on your monitor.. you are still limited by your monitors screen resolution.. in most cases 72dpi.. so what u really want to do is get as many dots in yoiuyr image as possible... what i do.. just before i render .. i switch my monitor to 1600 x 900.. speed to render: default render settings for hdri.. low qual ; 3 minutes mediam qual: 10-20 min high qual: 20 min to 10 hours!
Attached Link: http://graphics.stanford.edu/papers/envmap/
The probelight node appears to be an implementation of the algorithm behind the link. It is very fast at diffuse lighting, but does not do shadows.Attached Link: http://www.amazonescity.com/download/free3dformembers/oldplug.html
Here a link to old C4D 7 version, not tested, follow the readme, try it. ;) MazakAttached Link: http://www.amazonescity.com/download/free3dformembers/amazonesplughelp.html
Export wavefront objects in poser: File--> Export--> WavefrontObj... At Maxon.net you can download the free 8.1 update or the demo release. Tutorial how use the plugin: http://www.amazonescity.com/download/free3dformembers/amazonesplughelp.html Nicky's Forum: http://forums.mec4d.com/viewforum.php?f=36 MazakAttached Link: http://www.renderosity.com/viewed.ez?galleryid=434137&Start=13&Artist=Dash&ByArtist=Yes
Dash also uses C4D to render (NUDITY warning on link). I have v7.3, but so far just use it to model with (I haven't figured out how to do good lighting for renders in it yet).Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=455985&Start=13&Sectionid=19&filter_genre_id=0&Whats
I was checkingh the cinema 4d gallery and came across this incredible image of mike.. rendered in cinema 4d... point is u can download.. a full working demo of cinema 4d.. (save disabled) and then download a free plugin from "Amazone's City" http://www.amazonescity.com/ point is no need to wait for dazstudio or anyone else... check the image out.. speaks for itself... Nick
