Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
reflection maps are interesting features. for instance, if properly applied you can make objects appear as if they are reflected in a surface (even tho the object is nowhere in the actual scene file) or you can do some really kewl decorative effects like decorative mirrors...for instance a non -reflective decorative surface surrounded by a reflective mirror surface (many real world mirrors have this) not much info is available (that Ive seen) on the practical application of reflection maps (I may need to fix that ;)) good luck BT
If you have something that is reflective and you want to show it off without the expense in polygons, RAM, file size, then you use a reflection map to give the object something other than the sky to reflect. I usually end up creating projects with enough intresting stuff that I don't feel the need for reflection maps. Or I'll add the reflections in post production work in Photoshop.
opkay, I'm interested in using images as reflaction maps. BUT, what good are they, what can I do with them, what are they used for? I have a vague idea, but I'd like to know more
Talent is God's gift to you. Using it is your gift to God.
