Sun, Nov 24, 8:01 AM CST
Subject: technical texture mapping issue
Incarnadine ( ) posted Wed, 30 July 2003 at 10:02 PM ยท edited Sun, 24 November 2024 at 7:31 AM
I have a figure posed in front of a cube with a non-uniform or symetrical image texture applied. I want to apply the same texture to the poser figure at exactly the same scale. I have two problems in this. To get the texture to fit the cube properly I have to use Object cubic because even though the figure and the cube are the only objects in the model, world texturing shrinks the tex and tiles it! The texture is 1365x1024 pixels and the documenbt setup is 1024x768. What gives? Any ideas? The second is what mode given that world is out (at least until I understand the first issue) can match the scale/alignment issue. Any ideas will be welcommed!
MuddyGrub ( ) posted Wed, 30 July 2003 at 10:39 PM
This might be a dumb question, but did you try resizing the texture after you set it to world mode?
Incarnadine ( ) posted Wed, 30 July 2003 at 10:42 PM
Yup! it only seems to make the tiling even smaller! Aaargh!
MuddyGrub ( ) posted Wed, 30 July 2003 at 11:11 PM
Smaller? That's very odd and shouldn't happen. Try setting the X,Y,Z to "0%". Then try X,Y,Z set to "-1" percent and so on. The texture should map bigger.
Incarnadine ( ) posted Thu, 31 July 2003 at 6:23 AM
been digging in RWB and it just doesn't see to work, negative numbers deal with the frequency but with the image flipped 180 degrees. If you have scale picture size on, the values reflect the percentage size of the original image Aaargh! I didn't have scale pict size on. Then it becomes blindingly obvious that scales above 100% would do what I need! Thanks for helping me to see the trees!
Incarnadine ( ) posted Thu, 31 July 2003 at 7:38 AM
It is rendering at the moment at home. I will post results tonight when I get back!
Incarnadine ( ) posted Fri, 01 August 2003 at 6:50 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=460193&Start=1&Sectionid=2&filter_genre_id=0&WhatsNe
Well here is the result, a full size is posted at the link. I think it worked out well, myself. Thanks for the help. Much appreciated!
