Wed, Nov 20, 8:19 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Subject: How do I make a twoD image not so transperant?
herne ( ) posted Thu, 31 July 2003 at 10:18 AM · edited Wed, 20 November 2024 at 6:30 AM
I like the way the emage of the flamingo turned out for this picture however, I was messing around with a tutorial on how to incorperate 2d images into bryce and it said to make the back ground of the picture white. Unfortunatly it seems that everything that is white in the picture comes out transperant also. What am I missing?
Rochr ( ) posted Thu, 31 July 2003 at 11:17 AM
I think you mean black... :) With a transparency map for this one, everything ouside the bird should be black, and the bird itself must be flat white. Seems you have some darker areas inside the bird, thats why its transparent. Hope this helps. :)
Rudolf Herczog
Digital Artist
www.rochr.com
chohole ( ) posted Thu, 31 July 2003 at 12:57 PM
Square prop, and this is how the material editor looks
The greatest part of wisdom is learning to develop  the ineffable genius of extracting the "neither here nor there" out of any situation...."
herne ( ) posted Thu, 31 July 2003 at 10:41 PM
Okay, spacifically how did you do that? Did you cut the butterflies out of the picture in the second frame?
chohole ( ) posted Fri, 01 August 2003 at 1:01 AM
This was done in photoshop. The butterflies are on a seperate layer, and for the alpha map I turned them white using the Hue/saturation/lightness button, setting lightness to 100%. You could do the same in most paint programs that support layers, or even in a program that doesn't support layers by just masking the image area you want to turn white. If you don't have the lightness control you could always then paint the masked area white. I hope I an explaining this OK.
