Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 5:12 am)
Attached Link: http://forums.mec4d.com/viewtopic.php?t=760
Here is one of my test samples with P5 material room. I wrote a P5 minitutorial for photoreal textures. The Alberto texture is for free at Mec4D.com! MazakEmpressZario; The new skin looks good :) Share the P5 Material setting with us? PabloS; I can get in (http://mec4d.com/ here from Germany)! What browser did you use? Older Netscape version make trouble, I use IE. Mazak
Regarding the website.. I use I.E. 5.5 and without any problems I.E. 6.+ have to many Bucks..sure to check your Java enable setting.. I change the extensions for the Netscape and people don't have a big problems now.. and use for forums http://forums... http://gallery... and not http://www.forums that are subdomains that don't use www.. as Mazak wrote above.. EmpressZario your setting for the skin looks great in the first render... Cath
Like to give a warning on using Displacement. It does take a bit more resources to render. If you get carried away with the settings, perhaps turning it up higher than 1 you will notice a much larger render time. Add this with a detailed model and ... you get the picture. On one render I had the setting up to 5 and it took a good hour for the render bar to move past the n in rendering shadow. So be judicious with the setting. As regards your texture, be aware that realism includes irregularities. The smoother and more uniform the skin the less real it looks, especially on closeup. Wrinkles and freckles all make the skin a beautiful individual work of art. Little translucent hair follicle protrude from the skin making little bump which create grater sensitivity. So to me at least these things make the skin more appealing and sensual. Take a moment to look at the underside of the forearm. Even there you will see small hairs. Now gently trace your fingertips lightly down this skin. Notice the feeling. That's what makes the skin so sensuous and appealing and, that's what makes a sensuous skin texture. Now you don't need to get that detailed. Give a representation of some degree where the imagination can fill in all the subconscious intricacies.
