Sat, Jan 11, 12:11 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: Yummy Material Skin (Part 3)! Node image posted 2
EmpressZario ( ) posted Thu, 31 July 2003 at 7:43 PM · edited Fri, 10 January 2025 at 11:56 PM
Just gonna list some more samples of what I crapped out with this node function I'll post @ the bottom
EmpressZario ( ) posted Thu, 31 July 2003 at 7:45 PM
Take 2
EmpressZario ( ) posted Thu, 31 July 2003 at 7:46 PM
Take 3
EmpressZario ( ) posted Thu, 31 July 2003 at 7:47 PM
Take 4!
EmpressZario ( ) posted Thu, 31 July 2003 at 7:48 PM
This is for the head only, still working on the body
Dave ( ) posted Thu, 31 July 2003 at 10:23 PM
kewl
Mazak ( ) posted Fri, 01 August 2003 at 4:35 AM
Thank you :) Looks you make lot experiments before you get this result! Bravo! I hope Stewer add this to his P5 Material Room FAQ. Mazak
Google+ Bodo Nittel
alamanos ( ) posted Fri, 01 August 2003 at 8:28 AM
Excellent work.. very non poser like... what lighting setup did u use?
stewer ( ) posted Fri, 01 August 2003 at 9:32 AM
Adding that to the FAQ is a good idea - EmpressZario, do you mind if I add your material screenshot to my site?
Dave ( ) posted Fri, 01 August 2003 at 9:42 AM
did you ever come up with a SkinBody setting? Other than the spot value, what else would need to change in the SkinBody setup? Love the effect and now I gotta figure a fast way to apply it as a mat pose file or something. Unless of course somebody's already beaten me to the punch ;) Dave
EmpressZario ( ) posted Fri, 01 August 2003 at 10:06 AM
I wanna make sure what I'm doing is not only going to work in one lighting set-up (ie high intesity, global, or single spotlight). I'm working on a setting for the body that will sorta help seam the body and head and give the same resolution as the head. Stewer - yes you can add it to your website :) It's funny... this all started when I was trying to create a wax effect.
EmpressZario ( ) posted Fri, 01 August 2003 at 10:11 AM
Actually, in all the pics above I applied the same skin setting to the body and head (just made sure the right texture maps went to the right area) - it's just the body keeps coming out more blurry than the head, so I'm trying to work on that without getting the Pringle chip skin effect.
Dash ( ) posted Sun, 03 August 2003 at 7:23 PM
Hi i know this is an old thread but just had to try this and fiddle a bit. What i have found is that using the translucency settings make the skin look a bit better and receive llight even better. what I did is use the settings exactly as above, but changed the translucency color to a peach or brown color then set the translucency value at around .3 or .4 and connect your image map/texture map to your translucency color. There is a small difference as you can see here, all threee were rendered in the same lighting and pose, first default everything, second with the setting posted above and third with translucency on. anyways hope this helps, very interesting stuff :)
