Tue, Nov 26, 9:19 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: Using Multiple Grounds
camelot77 ( ) posted Fri, 01 August 2003 at 12:33 PM ยท edited Tue, 26 November 2024 at 7:40 AM
I find its easier to use the poser default ground than adding a ground prop, is there a way I can use multiple default grounds, I tried to copy and paste the ground but that does'nt seem to work.
lesbentley ( ) posted Fri, 01 August 2003 at 12:54 PM
Export the GROUND prop as an obj, reimport it (no ticks in any of the import options) and save it to a props pallet as Ground2.
camelot77 ( ) posted Fri, 01 August 2003 at 1:43 PM
very greatful
maclean ( ) posted Fri, 01 August 2003 at 2:54 PM
Or just import the original ground prop obj. You'll find it in Geometries/props. It's called ground20x20lines.obj. mac
geep ( ) posted Fri, 01 August 2003 at 3:09 PM
Or ... Use the GROUP TOOL ... 1. select the GROUND 2. open Group Edit 3. "New Group" 4. "Add All" 5. "Create New Prop" 6. name it "GROUND1" (or whatever you want) It will be an exact duplicate of the GROUND, except you can move/rotate it in all directions. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
