Or ... Use the GROUP TOOL ... 1. select the GROUND 2. open Group Edit 3. "New Group" 4. "Add All" 5. "Create New Prop" 6. name it "GROUND1" (or whatever you want) It will be an exact duplicate of the GROUND, except you can move/rotate it in all directions. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
I find its easier to use the poser default ground than adding a ground prop, is there a way I can use multiple default grounds, I tried to copy and paste the ground but that does'nt seem to work.
