Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
REMEMBER:
Black=masked
White=transparent
Using the Quick Mask mode lets you edit your selected area on the layer as a mask without using the Channels palette and while viewing your image. The advantage of doing it this way is that you can use almost any Photoshop tool or filter to modify the mask.
You could also add a new channel and add the mask you created into it. it's just the quick mask is faster...
retrocity
I've never understood this about Photoshop... why can't you simply copy and paste an image into a layer mask? The procedure that Jasonmit is attempting is something I've never succeeded in doing properly, and always ended up having to use a color range selection on the B&W image and then deleting from the image I wanted to mask. Retrocity, I tried following what you did there, but I ended up with a similar red picture to yours. How do you actually make the red area transparent? It seems weird that this kind of 2d compositing is far simpler to do in 3ds max. Even after effects handles alpha channels better.
the red layer is only in the " mask mode just click on the normal mode to exit quick mask , plus when you copy the image inot the mode you automatily get the right selction, ( i think pasting the black white into the quick mask will work ) then "delete the area"" you may have to stich from normal to quick mask and back just to get agrasp on what things you ar effecting on the layer..tip hide a layer you are not working on just so you can watch what happens to it. hehehe
edit...
the red layer is only in the " mask mode " just click on the normal mode to exit quick mask , plus when you copy the image into the mode you automatily get the right selction... then "delete the area" you may have to swich from normal to quick mask and back just to get a grasp on what things you ar effecting on the layer..tip hide a layer you are not working on just so you can watch what happens to the one you are working on
![file_69790.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_69790.jpg)
I have two images I would like to composite because I found that my image looks better with one section not antialiased. I have 3 images. The first completely antialiased, the second with no antialiasing, and the third a mask of the section (sofa pillows) I'd like to not have antialiasing in the final image. In easy, step-by-step language, how can I composite these images so only the pillows are not antialiased? Note: These images were created in another app.
