Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:11 am)
Several options:
Mark
Mark
Grouper tool works with props (or at least it does in P5, I assume it does in earlier versions.) Place pp2 and rsr in one of your library -> props -> ???? folders. Open poser Open prop folder and double click railing prop to bring it into scene. Select it. Select grouping tool. Edit away. -- Mark
Mark
Quick guide: First change the display setting to wireframe (it makes it easier to select back polygons. Select prop. Select grouping tool. In "Group editor" panel click "new group" and call it rails Now select the parts of the prop that belong to rails. (you can click on individual polys or drag a selection box around a group - hold down ctrl to deselect) Once all the parts you want to keep are selected (highlighted in red), click on "create prop" and again enter rails as the name. Close the group editor panel. There will now be two props in scene, the original one and your new rails one. There we go, quick and dirty prop slicing. Note, you may find that the ends of your new prop now have holes where they would originally have joined to the squares. Hope that helps Mark
Mark
I was wondering how I would remove the corner ends from some railing? I just need the railing but not the corner boxes.
