Mon, Nov 25, 6:43 PM CST
Subject: Firefly gave me real skin
Mesh_Magick ( ) posted Wed, 06 August 2003 at 1:30 PM · edited Mon, 25 November 2024 at 4:36 PM
I was playing and tinkering and tweeking, grinding my teeth,cussing a fit,tinkering,tweeking then something wierd happend I noticed one of my renderings was looking oh my goodness jumping pussy cats! the trick and I had to figure this out by dtopping a minmute to think how I did it, was reduce color saturation by at least 60 percent in the texture and I used a very interesting complex lighting preset by adding lots of shadow lights a grey light and mustard light into the scene and got this awsome rendering without any skin bump, all he has is a vascilar bump, hmmmmm. Now if I can only get this darn leather to to look like leather.
bijouchat ( ) posted Wed, 06 August 2003 at 2:01 PM
damn, that's really nice work! Well done!
Mesh_Magick ( ) posted Wed, 06 August 2003 at 2:03 PM
here a better look at him.
Mesh_Magick ( ) posted Wed, 06 August 2003 at 2:18 PM
last picture
neftis ( ) posted Wed, 06 August 2003 at 2:40 PM
To reduce the percentage of the color will indeed create a kinda translucidity...addind the bumps is even more real and shows better skin texture when the color is a little fade-out. !!It looks indeed more real...and you can as well do this in poser 4 or 5. Nice job! I like your work! Nef
TrekkieGrrrl ( ) posted Wed, 06 August 2003 at 2:55 PM
'P.S. Did you know that Peter O'Toole has a double phallic name?' -- Groucho Marx in a letter. Or in other words... U forgot the nudity tag ;o) But your skin is looking good :o)
Mesh_Magick ( ) posted Wed, 06 August 2003 at 3:24 PM
oh yeah, I remember nest time.
Mesh_Magick ( ) posted Wed, 06 August 2003 at 3:28 PM
Nef can you load both a vascular map and a body texture map in poser 5 and layer the 2 bumps to interact with wach other in a rendering all on the same figure at the same time? By the way thanks Nef, Ill be sure to visit your gallery.
Mesh_Magick ( ) posted Wed, 06 August 2003 at 3:32 PM
I got one more question, can I set collsions for the poser figure so that when I conform clothes they fit and don't pass through the Mike figure no matter what his full body morphs, how does this stuff with the collsion and wrinkle room work?
Little_Dragon ( ) posted Wed, 06 August 2003 at 5:47 PM
You can use a Blender node to combine two bump maps.
Or you could plug one map into the bump channel, and the other into displacement.
Riddokun ( ) posted Wed, 06 August 2003 at 9:20 PM
forget me if i am wrong, but given the screenshot you put of the interface, i suppose your trick needs poser 5 to work, ney ? I mean you seems to use options that you apply directly from poser, yet those kind of settings on textures are alien to me (poser 4 nopropack) btw it is interesting, as it still give an idea to follow, simply by preprocessing a texture with a paint software, then using it in old poser (along with lightings) and see what it does...
Mesh_Magick ( ) posted Thu, 07 August 2003 at 5:17 AM
check out the shadows on the arms of the nude guy, It kinda really does add a interesting effect to the skin giving it more depth.
GraphicFoxx ( ) posted Thu, 07 August 2003 at 11:18 AM
Collisions work oddly. Just like that sentence came out. Egads. Anyway, apparently collisions can stop a figure from going through himself, but for other objects, it just shows when you have a collision (if you have show collisions checked).
