Okay .. I think you aren't finishing the process. if you are patched and want to export a head morph for example you would go through the export process and then would get the heiarchy sheet for what you want to export and then you click just the head. At this point it will ask how many frames (or before, not positive) and then you should have another dialog box that comes up asking for things like "mexport as a morph target", "weld seams" and stuff liek that .. if you dn't have that then you are not fully patched ... hope that helps
Allright! Success!... Thank you, Ghostofmacbeth! I guess I was fully-patched after all... I was overlooking exactly what you suggested here. I had been under the impression that this dialog box I was looking for would appear BEFORE choosing a place to put it, since, in Windows, that's usually the final say in the matter. I should have realized it myself, though, because Meta C's Painter 6 does the same sort of thing. Thanks again!!!! :) Take care! Mike
Hello again...sorry to be such a pain about this, but: Ok, I got the patch installed, and I'm pretty sure I did it right, but I won't swear to it, although the Rattlesnake now "works". Supposedly I should now have a 3rd dialog box under export as Wavefront.OBJ, enabling a "save as morph target". Still, though, all I get is only the box where you choose what parts to export, and I never see any 3rd box....except for the box which Windows uses to ask me where I want to put it all, but I'm asuming that THAT'S not what I'm looking for. All I get is the box where you choose how many frames to export, and then the box to choose what how much of it to export, but never any option for morph targets. The reason I say I won't swear to having installed the patch correctly, is because the Read Me seems to differ with what I actually got unzipped, such as there is supposed to be a folder called, "Put in Poser folder", but there is none. I simply followed the hiearchy of folders in the patch when I installed it into Poser. I deleted the former plug-ins, as it said... I did everything EXACTLY as it said, for that matter. Is there a better version of this patch "out there"? I have tried it with 3 different versions of it, #1, the original Meta Creations version, #2, the current version at Curious Labs' site, and, #3, the version at Poser World. They all seem to be exactly the same version. Please help? Any advice? Something I'm overlooking? Thank you... Mike
