Thu, Dec 26, 9:33 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: If you are having prob with HDRI
res1yfb1 ( ) posted Thu, 07 August 2003 at 2:39 PM ยท edited Thu, 26 December 2024 at 9:09 PM
Attached Link: http://www.kirksaavedra.com
It is very important to FLIP your HDRI MAP if your pic rendres to dark. my tutorial will show you how to do this. I hope this helps kirk saavedra
res1yfb1 ( ) posted Thu, 07 August 2003 at 3:07 PM
Here are two pics showing you if the pic is the right way and if the HDRI MAP is upside down
res1yfb1 ( ) posted Thu, 07 August 2003 at 3:08 PM
and the dark pic is the same HDRI MAP...but it is the wrong way...it is upside down. I hope this helps kirk saavedra
poserpro ( ) posted Thu, 07 August 2003 at 4:09 PM
can we use the hdr map to illuminate the scene objects, any tut is appreciated.
Hoofdcommissaris ( ) posted Thu, 07 August 2003 at 4:45 PM
Mmm. It looks in the above images it actually looks like the map IS illuminating the scene. Why would it be so dark otherwise? I am going to try this!
poserpro ( ) posted Thu, 07 August 2003 at 4:49 PM
it was illuminated by Sky Light.
res1yfb1 ( ) posted Thu, 07 August 2003 at 5:45 PM
The scene is lighted by the HDRI MAp...Thats what it is for. HDRI MAPS are for reflections and light...I have a tutorial on my website. I hope this helps. kirk saavedra
res1yfb1 ( ) posted Thu, 07 August 2003 at 6:30 PM
SKY LIGHT is not a light....all it does is it pulls the information from the HDRI MAP and turns the hdri map into light.. hope this helps kirk saavedra
poserpro ( ) posted Thu, 07 August 2003 at 7:17 PM
strange, no matter which hdr map ( with different color range ) i use, all i got is a scene with blue tint, so i doubt if hdr map actually illuminates the scene.
res1yfb1 ( ) posted Thu, 07 August 2003 at 8:02 PM
if you go to my website and look at the three HDRI maps i have their you will see three diffrent light levels do to the diffrent HDRI MAPS.. all the settings are the exact SAME in every pic...Just a diffrent HDRI MAP.. are you sure you have the sky light button on? Because if you dont, it cant read the Light in the HDRI MAP. kirk saavedra
mindways ( ) posted Thu, 07 August 2003 at 11:27 PM
Ya posepro. Apparently it need to setup skylight + HDRI map to illuminate scene with objects. Just a thumb rule to remenber using in Carrara. Colour range of your hdri map isn't affect as seen in other program. Ed
