Thu, Feb 13, 3:21 AM CST
Subject: So; how do I make a flame look believable anyways? :)
brittmccary ( ) posted Thu, 07 August 2003 at 8:26 PM · edited Sun, 09 February 2025 at 6:08 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=465344&Start=1&Sectionid=2&filter_genre_id=0&WhatsNe
I posted an image to the gallery. One that has been lurking a while, I think. :) I'm playing with lights.. atmosphere and lightsettings in the "studio". One thing I can't quite figure out is how I make a flame look a bit realistic. I've tried a light surrounding the flame object; volumetric and not. Tried to put the default "flame" texture on the model WITH and WITHOUT light surrounding it... I can't make it look very good, so I ended up cropping the candle light out of the image (see link)... Any secrets out there that you'd want to share with me?? Thanks! Britt :)
MadDog31 ( ) posted Thu, 07 August 2003 at 9:36 PM
What I've done in the past with flames and fire are basically putting a picture of a flame on a 2D plane and then adding a couple of light spheres in front of it to give it some brightness... MD
antevark ( ) posted Thu, 07 August 2003 at 11:45 PM
Wow, bizarre. Looks great, almost painted. I like it a lot. I found a great tut a while ago, I'll see if I can find it.
antevark ( ) posted Thu, 07 August 2003 at 11:48 PM
Attached Link: http://www.antialias.info/tuto/firemat.pdf
Here it is, it's in pdf format, so make sure you have Adobe Acrobat.
Bladesmith ( ) posted Fri, 08 August 2003 at 2:20 AM
Crank the ambiance way up, make it transparent to some degree, and put a light inside of it. Turn off cast and recieve shadows. Clay has a great fire mat off in freestuff (great for billowing infernoes, not really for candles), and Pinhead over at the 3dcommune made some really nice fire mats in the freestuff there. You got very good results in the image, BTW.
electroglyph ( ) posted Fri, 08 August 2003 at 8:20 AM
Any Tips for gels on lights. I tried some fire mats and they all stank. I've had good luck with caustics for water though.
brittmccary ( ) posted Sat, 09 August 2003 at 6:52 PM
Thank you for your comments here and in the gallery! :) That means a lot to me. I was able to bookmark the tutorial before the power supply on my computer went kaboom. So I'll certainly go through it, and post the result! :) Britt
