Hey, First porb I think you 'replaced' the coat with the figuer. Don't double click the coat just click on the two checkmarks. (And not the one check mark). Second prob : Use the Confirm to. You can find it at edit I think. Then just select Figuer 1 (If you didnt rename the Figuer) and click ok and you're set. Hope this helps :) Happy Rend's ~GI
OK One question at a time: The pop up is for when you've double clicked something, that means generally: Oh cr*p, I double clicked again ;o) Just cancel it. Unless you really WANT to replace the current character of course. I never check any of the checkmarks so I'm not sure what difference they make. Then, When you put clothes on top of each other, poke thru's are almost bound to happen. In general you'll have to postwork yourself out of that, in Photoshop, or Paintshop or Gimp or whatever you prefer :o) When you morph your character the clothes will no longer fit. A program that can help is The Tailor, you can get it at Daz3D, but it costs money, which I remember you mentioned you had very little of :o) How doesn't the Feodora fit? Have you tried to scale it? Perhaps only in for instance the x-direction? You CAN try to scale the clothes too to make him look buff, but in general it won't work. Hope that helped a bit :o)
I have a couple questions. First off why does my characters figure dissapear when i try to put a trenchcoat on em. Secondly how come the clothes dont pose with the char. I'm so confused help! -Heliix
