Sun, Jan 26, 5:24 PM CST
Subject: Poser 5 and Daz UpDo2 - help please
wenke ( ) posted Sun, 10 August 2003 at 5:49 AM · edited Sun, 26 January 2025 at 5:23 PM
Actually I work on new textures for the UpDo. I have P5 with the latest SR. I have tried every displacement tip for texture and/or transpary setting, but the hair looks always blocky in my render :o( Can anybody help?
Mazak ( ) posted Sun, 10 August 2003 at 6:35 AM
Schalte mal 'use texture filtering' ein. UpDo2 braucht keine displacement map (habs gerade mal getestet) Wenn Du willst mache ich screenshots. Mazak
Google+ Bodo Nittel
wenke ( ) posted Sun, 10 August 2003 at 6:52 AM
Danke Mazak, dass Dumme ist, dass die Bodytextur mit dem Texturfilter ziemlich extrem wird. Ich hab jetzt im production modus mit den default settings gerendert.
Mazak ( ) posted Sun, 10 August 2003 at 7:01 AM
Ja ist ne leidige Sache :-( Aber mach zwei Bilder eins f die Haare und eins f den Kper. Dann mit Photoshop zusammen fen ;-) Mazak
Google+ Bodo Nittel
Engel47 ( ) posted Sun, 10 August 2003 at 7:04 AM
Would it be at all possible for someone to translate the answer into English, for those of us with the same, or similar problems that don't speak German?? Thanks.
wenke ( ) posted Sun, 10 August 2003 at 7:07 AM
Hi Engel47, o.k. so if you want, that the hair don't looks blocky use texture filtering. But with this setting the body texture looks sometimes very extreme (image 2). So you must choose good looking hair or good looking character texture. Or you make two images (one for the hair and one for the body) and put them together in Photoshop.
Mazak ( ) posted Sun, 10 August 2003 at 7:10 AM
I say: uses use texture filtering in render settings and UpDo2 dont need a displacement map. That helps for transparent maps but sometimes it makes strange effects with texture maps. Mazak
Google+ Bodo Nittel
LOL crosspost ;) Mazak
Google+ Bodo Nittel
wenke ( ) posted Sun, 10 August 2003 at 7:12 AM
Danke nochmal Mazak ;o)
Mazak ( ) posted Sun, 10 August 2003 at 7:14 AM
Don't forget to translate! "Thank you again Mazak ;o)" Hehehehehehe.... ;-) Mazak
Google+ Bodo Nittel
stewer ( ) posted Sun, 10 August 2003 at 7:42 AM
The blocks I see in the first picture look like regular aliasing to me - wenke, try setting a higher number of pixel samples and/or setting the post filter size to 2 and the type to gauss. Stefan
Momcat ( ) posted Sun, 10 August 2003 at 9:49 AM
That is the nicest I've seen the version 2 DAZ hairs look yet. I
hope you will also do some for the new Flip Hair. I tried, but it
still looks very dry to me. Yours looks nice and soft >^_^
wenke ( ) posted Sun, 10 August 2003 at 10:19 AM
@ Momcat: Thanks and yes I also make textures for the Flip Hair too :o)
FishNose ( ) posted Sun, 10 August 2003 at 1:24 PM
Guys, I've been wondering - I have the original Flip and Updo. Are the new versions significantly better? Is there a good reason to get them? :] Fish
Engel47 ( ) posted Sun, 10 August 2003 at 3:47 PM
Mazak und Wenke thank you for being so understanding and reposting the answer in English, it is appreciated.
