Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
The standard for 35mm scans is 3K x 2K, 3072 x 2048 pixels, 2000 dpi, but dpi doesn't really mean anything while your in Poser, there are no real inches in your computer. a 3K x 2K imagew can be 72 dpi or 10,000 dpi, it is the quanity of pixels that count. The 35 mm image from a good camera is higher quality than can be contained in a 3K x 2K, Kodak will scan a slide for you at 4000 dpi.
momodot; jpg compressoin depends on the image. Also jpg has lots of compression modes. 1:2 1:4 and so on. I just picked up a 3.3 megapixle (2048 x 1536 pixel) camera and it will give me great images in jpg format from 400k - 1.6M or so in size. http://www.olympusamerica.com/product.asp?c=78&s=12&p=16&product=521 I have a 16 meg card in the camera and it will hold 20 images that are of great quality for 8X10 prints. You should be able to fit a graet image on one floppy. also it's good to have a great printer as well like the Epson 1270. http://www.epson.com/printer/inkjet/sty1270/ Hope this helps
You can't call it work if you love
it... Zen
Tambour
Kodak claims the equivilent of 20 megapixels per 35mm frame for Kodachrome film. Works out to something like 4000x5000 pixels. Poser only renders at 3090 max pixels. DPI does not matter until you are printing out on paper. Hirez film scanners are advertised that do up to 8000. (I know that does not add up if the film will only do 4K x 5K but those are the numbers that are out there)
3.3 megapixle (2048 x 1536 pixel) = 400k - 1.6M Thank you Spike, that is just the information that will help me. I have been doing my art for the web at under 400x600 since I have no printer, I was wondering what a good size would be if I want to someday print them, but my only back-up media is floppies. This 2049x1536 dimension gives me the idea that maybe I should use that as a base image size.
Yes it will because it is not compressed. But be warned the file size can get big fast. 2048 x 1536 pixel tiff = around 16 meg
it... Zen
Tambour
Oh one more thing. things to keep in mind when rendering your image. The most common standard for printouts is 300 dpi So if you wanted a 8X10 print at 300 dpi your rendered image would have to be 2400 X 3000. The math: 8" X 300dpi = 2400 dpi because there will be 300 dots per inch printed. 10" X 300dpi = 3000 dpi. I have however found that with my new setup as listed above I can make some killer prints at 200 dpi. and I still can't belive my eyes. I never thought I would ever say that digital cameras rock and are just as good if not better then standard 35mm camers. (this is not to say that they will be replaced because as of yet most don't offer the same lens changing options unless you spend lots and lots). but they do offer some cool things like ya don't have to spend 13 bucks having prints made only to find out only one looks good and you just spent 13 bucks on one 3 X 5 print. And they are fast. I went from studio to 8 X 10 print in 10 min.
it... Zen
Tambour
What should the "render options" resolutions be in order to receive a jpg file with the same resolution as a 35mm camera? Should it be pixels/inch or pixesl/cm. Does it need to be 72 dpi or 720 dpi or 3500dpi or does it even make a difference? What's the formula - I'd also like to know the dpi in order to emulate a 64mm film camera. Thanks everyone for the help on the other questions.
