Wed, Feb 26, 2:35 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2025 Feb 23 2:34 pm)
Subject: Pose Files
ricewind ( ) posted Thu, 14 August 2003 at 7:50 AM · edited Tue, 25 February 2025 at 8:54 PM
Is there a way to give a figure a specific name through a pose file? And also - drop it to the floor?
lesbentley ( ) posted Thu, 14 August 2003 at 1:07 PM
Suprisingly in Poser 4 it does not seem posible to rename the figure via a pose file. You might expect this to work; { version { number 4.01 } figure { name New Name } } but it does not! "Drop to Floor" Can't be implemented through a pose file either (as far as I know). However this does not matter in most circumstances as you can just position the figure on the floor. The best way to do this is probably to set the yTran for the BODY to zero, then yTran the hip (or whatever the base parent body part is) untill the figure touches the floor. Make a note of the yTran value of the hip then insert it in a pose file, like this:
version
        number
actor BODY
        channels
                translateY ytran
                        keys
                                k  0  0
actor hip
        channels
                translateY ytran
                        keys
                                k  0  -0.007
lesbentley ( ) posted Thu, 14 August 2003 at 1:38 PM
If you do not understand making pose files in a text editor you can use the free utility Mat Pose Edit. Just set the position for the figure as in post #2, save a cr2. Open it in Mat Pose Edit, when prompted to load morph and pose data answer YES. Delete all the materials (actually there is a bug in version 2.0.3 that means you have to leave one material, "pupil" is good choices to leave). Delete all the actors except "BODY" and "hip". Delete all the channels from the remaining actors except "ytran". Save out a pz2.
ricewind ( ) posted Thu, 14 August 2003 at 6:17 PM
Thanks!
