Fri, Jan 24, 6:44 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Change AVI default?
gddesign ( ) posted Wed, 13 August 2003 at 9:17 PM ยท edited Fri, 24 January 2025 at 6:41 AM
When I'm making movies I almost always want to save separate images, not AVI's. The bloody dialog box always defaults to AVI and I have to change it every time!! Is there a way to make images, not AVI's, the default selection?
cruzan ( ) posted Thu, 14 August 2003 at 6:45 AM
When you get everything set up the way you want - make a movie with settings that you want for default (you can cancel after a frame or two is written) then do Edit General Preferences and Launch to Preferred State. I just did it and every new file, every time I reopened poser5 - the settings were exactly as I had set them
smiller1 ( ) posted Thu, 14 August 2003 at 9:48 AM
Plus- For each Poser scene (pz3 file), if you save it after rendering it saves the render settings for that scene, including this option.
gddesign ( ) posted Thu, 14 August 2003 at 4:52 PM
I'm running v4.03 and these suggestions aren't working. This may be a glitch in Poser4.
Spit ( ) posted Thu, 14 August 2003 at 8:24 PM
It does work in Poser 4. You also have to 'set preferred state'. There was a step missing. This tells Poser that what you currently have is what you want as the preferred state.
