Sat, Feb 8, 12:54 PM CST
Subject: How do Transparency maps work
HAE_Inc ( ) posted Thu, 14 August 2003 at 5:09 PM · edited Sat, 08 February 2025 at 12:53 PM
Hi,
How could I use a transparency map to create like an opening in a standard poser cube so it looks like a window, is this possible or what b/c i made a transparent image and set it as the transparent map in the materials box and it did create an opening in the cube but the cube that wasn't completely transparent as a result of the map was semi-transparent as i had to set the transparency max to 100%. Is there any way around this so the part that i didn't make transparent in the image won't be transparent?
Whu, thats a long one, lol
Thanks
Helen ( ) posted Thu, 14 August 2003 at 5:28 PM
You need to use a transparency map. When making a transparency map one thing to remember is that 100% black is complete transparency and any lighter shade (usually greys)gives less transparency. The lighter the grey the more visible an object becomes. To have part of an object transparent while keeping parts visible your trans map would be black where you want the transparency and white where you want to see parts. I would suggest a shade of grey to make glass. Trial and error really until you get the look you want. You still set your transparency dial to 100% Helen
Senior MarketPlace Tester
If anyone sees a mind wandering aimlessly around..... It is mine.  I want it back.
maclean ( ) posted Thu, 14 August 2003 at 6:12 PM
Hae, You might have better luck using the poser one-sided square intead of a cube. In theory, the trans map on a cube should go on both the front and back, so perhaps that's why you're not getting the results you want. I can't say for sure without seeing what you did, but the one-sided square may work better. mac
EricofSD ( ) posted Thu, 14 August 2003 at 10:23 PM
If you need to use the cube then maybe using uvmapper will help you get the transmap positined correctly so that the hole is on both sides.
