Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 02 8:21 pm)
The MANUAL is HARD if you are a newbie.Steve/Larry should make it an auto one.We spent ALOT of $$$ on POSER over the years.That is not too much to ask.I FINALLY got the Auto one to work.You HAVE to TOTALLY Delete your old poser files.ALL of them(Save your work somewhere first).Then Re install poser,do the update THEN add your stuff.It Works! :)
I've seen this before... it sounds like they're using the same update system that id used waay back when for Doom (only this is the win32 one obviously - sorry about the strange link, I can't for the life of me remember what the system is called). It's not that awful english at all, it's actually perfectly correct - ladies and gents, if you've been using the unofficial updates since buying Poser 4 then it's your own fault for not heeding the warnings - official updates like this 4.02 updater will always look for the official 4.00 Poser 4 EXE - if you remember the beta updates were never officially sanctioned by MetaCreations. Use Winzip, Winace or something to extract the original Poser.EXE from the huge .CAB on your poser CD (making a copy of the current one just in case), and try the updater again. If it says similar things about other files then backup and overwrite them in the same manner.
Hello, long time no post any questions. Okay, I slow. I just decided to update Poser4.0 to 4.02. I downloaded the auto updater on Curious Labs site. (little over 2mgs) When it starts running, it asks for Poser exe 4.00, I find it and it starts the update. Then it stops and I get this message. "Old file not found. However, a file of the same name was found. No update done since file contents do not match." I don't understand this or how to correct it. Any one have any suggestions? Thanks, Bill
