Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 2:19 pm)
this happens when poser crashes. what I did was make a copy of that xml library file and when I crash I just move it back. Poser will automatically rebuild it after most crashes, but I've noticed that it defaults back to when you first installed and you have to re-enter all the addtl runtime folders you added.
Last night while I was working with Poser I clicked something near the first drop down menu, not sure what as my mouse slipped. Then Poser shutdown.
When I tried to open Poser after that I kept getting an: XML error at line... not well formed error log is being created, type of message.
This meant that I couldn't open Poser up whatever I tried.
Eventually I found by looking at files created in last 24 hours that the offending file was my Library prefs. I ended up renaming an extra Runtime that I'd created and amending the Library prefs file to reflect this name/path change.
Pheeew it worked out fine in the end.
Does anyone know how I managed to get the error up in the first place, what on earth did I do wrong?
Thanks
Mit
