Fri, Jan 24, 7:51 PM CST
Subject: Looking to figure height in Poser
Shilar ( ) posted Thu, 21 August 2003 at 10:12 AM · edited Fri, 24 January 2025 at 7:51 PM
I have several characters with varying heights, and want to show this in a montage. Is there help in figuring out the difference in height in accordance to sight? Any website/tutorials will be much appreciated.
rhiafaery ( ) posted Thu, 21 August 2003 at 10:51 AM
There are a few threads floating around here pertaining to this issue. http://www.renderosity.com/messages.ez?Form.ShowMessage=1352228 http://www.renderosity.com/messages.ez?Form.ShowMessage=1365626 Hope that helps. :)
BAM ( ) posted Thu, 21 August 2003 at 12:41 PM
Their has been quite a bit of discussion on this topic. Try searching for scale, unit, and ruler in the Poser forum. Also, you may want to search for Geep as he has taken particular interest in this, written a tutorial or two (http://galileo.spaceports.com/~schoolin/)and engaged in conversations on this topic. Good luck
BAM ( ) posted Thu, 21 August 2003 at 12:42 PM
Oops, seems like http://galileo.spaceports.com/~schoolin/ is no longer valid. Anyone know where they might be found now?
Shilar ( ) posted Thu, 21 August 2003 at 5:03 PM
Actually, it seems I'm back to square one. What would be handy is a simple "Point of View" measurement for different heights, instead of needing to break out calculators.
geep ( ) posted Thu, 21 August 2003 at 11:54 PM
Do you want it in feet or meters?
cheers,
dr geep ... :o]
edited 10/5/2019
Shilar ( ) posted Fri, 22 August 2003 at 6:35 AM
Feet is great. I did find the caliper prop and is helping better.
geep ( ) posted Fri, 22 August 2003 at 8:01 AM
Would this help?
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 22 August 2003 at 8:14 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 22 August 2003 at 8:22 AM
cheers,
dr geep ... :o]
edited 10/5/2019
maclean ( ) posted Fri, 22 August 2003 at 3:50 PM
Whatever method you use to measure height, make SURE you use the Front Camera in Poser to do it. It's the only reliable viewpoint Poser has, since it can neither tilt not rotate. mac
Shilar ( ) posted Fri, 22 August 2003 at 7:36 PM
Thank Mac, I am using the caliper prop, which gives me a viewpoint relationship to the height.
