Wed, Feb 5, 9:39 AM CST
Subject: Rendering 2D images in Bryce
Mivan ( ) posted Thu, 21 August 2003 at 7:37 PM · edited Thu, 30 January 2025 at 3:33 PM
I have been trying to create images in Bryce by mapping different fractal images to a cube as materials. Each imported pic file is about 9 megs. When I find one I like and render the image I would like to create a finished product of 100ppi at a size of 16X20 inches. My rendered images display some very smooth areas and also some that appear to be pixelated. Since I have set render size to larger than 16X20 in order to resize to a 100ppi image in photoshop to compensate for the 72ppi Bryce limit I am now wondering if pixelation is a function of larger renders in Bryce or it is due to a depth of field situation. The render documentation window is set for superfine but the problem continues. Any guidance will be greatly appreciated. Mivan
AgentSmith ( ) posted Thu, 21 August 2003 at 7:55 PM
Actually, you can render in any dpi you want to in Bryce, just type in what you need. AS
catlin_mc ( ) posted Thu, 21 August 2003 at 8:03 PM
You beat me to it AS, I was just going to say that.............8)
AgentSmith ( ) posted Thu, 21 August 2003 at 8:04 PM
The issue of textures looking pixelated in large renders is due to the original dimension of the texture itself. I assume if your textures are 9Mb each they are of a fair size, dimension-wise? Are your textures uncompressed images? If so, they are most likely around 2000x3000 pixels. That should be decent for the size you are rendering. Also, try a test render with no d.o.f., see if there is any change. Hard to be more specific without seein the pic firsthand. AgentSmith
AgentSmith ( ) posted Thu, 21 August 2003 at 8:05 PM
And, it just may be due to the re-sizing in Photoshop. AS
JC_01 ( ) posted Fri, 22 August 2003 at 12:05 AM
lol maybe it's the late hour, or maybe it's the lack of focus right now, but huh? that one went like 3 feet over my head....lol soooooooo happy you guys are so smart...grins
danamo ( ) posted Fri, 22 August 2003 at 12:32 AM
I am curious Mivan, are you trying to map the same material, or fractal to all the faces of a cube?
Mivan ( ) posted Fri, 22 August 2003 at 5:32 AM
I've been trying to to the tagliatelle of the gods tutorial and some of the renders have been ok and some have not. The ps files are not compressed and the pixelation effect can be seen on screen in Bryce which kind of leads me to the depth of field theory. My camera may be too close to the cube. The only other thing I come up with is perhaps the original photoshop images may need to be square rather than rectangular to better fit the cube dimension. Mivan
Mivan ( ) posted Fri, 22 August 2003 at 5:44 AM
Oops; I said I was doing the tagliatlle of the gods tutorial when I meant the disrupted fractals tutorialhttp://www.j.b.allen.btinternet.co.uk/fracttut/disfractut.html. Its too early in the morning here and I'm only on my second pot of coffee. Mivan
catlin_mc ( ) posted Fri, 22 August 2003 at 7:14 AM
You should never write to the forum Mivan until you've finished at least 3 pots of coffee.................8)
Gog ( ) posted Fri, 22 August 2003 at 7:25 AM
Mivan, I think you've probably cracked it with regards aspect ratio of the images being mapped onto the cube. As said earlier in the thread, Bryce doesn't actually set the dpi of an image unless you're rendering to disk. any other time just workout size using print size(inches) x DPI and setting the resolution to the calculated values. I think BryceTech has an online calculator on his tut pages:-). Graham
Toolset: Blender, GIMP, Indigo Render, LuxRender, TopMod, Knotplot, Ivy Gen, Plant Studio.
catlin_mc ( ) posted Fri, 22 August 2003 at 7:34 AM
Attached Link: http://www.brycetech.com/
And here's the link to BryceTech. The link is on the left of the page under tutorials "Printing Resolutions". Catlin
Zhann ( ) posted Fri, 22 August 2003 at 2:37 PM
I've done the tut you're refering to and haven't had that problem. I've used the KPT fraxflame to create the fractals, and then brought them into bryce, mapped to the cube with no pixelation at all....this is really strange, but try the suggestions above see if they help. An image here would also help everyone see your problem....8) Zhann
Bryce Forum Coordinator....
