Fri, Jan 31, 11:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Gun Shot Blast
nivek ( ) posted Sat, 23 August 2003 at 8:18 PM ยท edited Fri, 24 January 2025 at 1:08 AM
Does anyone know of any tutorials for creating a gun shot blast in an animation? I've attached a picture of a gun shot blast I created in Paint Shop Pro. It look ok when it flashes on the screen during an animation but I'd like to create something more realistic. Thanks Nivek
Dave-So ( ) posted Sat, 23 August 2003 at 9:59 PM
Attached Link: http://www.wondertouch.com/se_info.asp
There's a program called Particleillusion that is being given away on DIGIT mag CD...mag cost about $14 in US.... $99 on the product website... Unforntunately, I ran around all over town tonigh and couldn't find Digit anywhere.
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
Little_Dragon ( ) posted Sun, 24 August 2003 at 12:56 AM
You can order a copy of that issue (#64, August 2030) directly from the website, if you can't find it on newstands.
http://www.digitmag.co.uk/
I have a flame prop in the Free Stuff Club at PoserPros, which might make an adequate muzzle-flash if parented to the gun. You can keyframe the prop's scale to make it appear and disappear at an appropriate moment during the animation.
nyguy ( ) posted Sun, 24 August 2003 at 2:07 AM
here is a litle trick you can try, create a block prop and set it to white then take an avi file of a gun flash or explosion and use the avi as the texture it should work
Poserverse The New Home for NYGUY's Freebies
Mason ( ) posted Sun, 24 August 2003 at 3:06 PM
also try alamdv at www.alamdv.com. Nice post work program and its like $68. I use it for lightning bolts, particle beams, sparks explosions etc.
Charlie_Tuna ( ) posted Sun, 24 August 2003 at 11:43 PM
That's western .44 in the pic so the flash is pretty close to reality since the powder used in them burns slower than that used in modern guns. So the will be a muzzle blast although it would be more a blast of greyish smoke with only flecks of red in that lighting, the red/yellow flash would appear only on much lower lighting. Ratteler, Muzzle blast does not equate to how hard the bullet is going hit, a .38 coming out of a 1 inch barrel with a 3 in. muzzle flash will hit just as hard as one from a 6 in barrel with very little flash.
Why shouldn't speech be free? Very little of it is worth anything.
genny ( ) posted Mon, 25 August 2003 at 12:28 PM
Attached Link: http://RustyIrn.homestead.com/GunFire.html
This took me about 1/2 hour to render as a Gif file. It really took longer to save in Poser4 as a AVI then anything else. I used a program called "Alam" which is not free but as a registered member, you can download any new updates (Plug-ins) you want for free. I apologize if my effects are not "realistic", and as much as my Husband is a fancier of "black-powder" stuff, you would think I could remember exactly what it looks like when it goes off! LOL! But, as many times I have seen it.......all I can remember is the smoke! (: Anyway, go check it out........it is really easy to use and it is under a hundred bucks.......last I checked anyways. (: Genny THIS IS THEIR URL: http://fxhome.com/
