The Anime-face dial is on the head of the Vickie figure - IIRC there was an updated figure released with a whole bunch of morphs for the face/body by Zygote. Check your camera settings as well, the default for the face camera is something silly like a simulated 38mm lens. This causes horrible distortion of the face - even on Posette. Set it up to about 60mm (as a minimum) and move the camera back along the z-axis. This will make the face look less distorted. Also remember that, if you crank most morph-dials much past 1, you will get strange and unexpected results :) Paul
I couldn't find and "Focal Length" on the dials at the top. I switched to the face camera and selected head. The head parameters came up but their was no focal length. What exactly do you mean by "dials, right at the top"? Are these the parameter dials located to the right of the document window? Kimberly krbtv@home.com
Does anyone know what head dial parameters are used in order to get the Victoria Head Morph woman with the Red Hair ( the one called Anime - not the Faerie)? The woman I'm talking about is on the 2nd row, 2nd column. She's directly below the woman with the glasses. The picture can be found via the Millennium Woman page: (http://store.zygote.com/cgi-bin/miva?Merchant/merchant.mv+Screen=PROD&&Store_Code=ZP1&Product_Code=ps_pe017) Click the Victoria morph targets at the bottom of the page. I tried to create a woman like her and mine looked like a poodle. Thanks, Kimberly Brugier
