Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
If I've understood you correctly the walk designer has given you an arm that swings?
Open up the Key Frame Editor and select the collar, shoulder forearm and fingers for frames two through to the end. Next click the Delete Key Frames button. Now select frame one and pose the arm. This pose will now be carried through to the end.
Im trying to do an animation with a man holding a gun up while walking , i did the walk designer for the walk and i put the arm up but now how do i lock that position so that the animation continues with the arm in the same place?
