Mon, Jan 27, 8:01 PM CST
Subject: Is this a DTE Bug????
Roch222 ( ) posted Thu, 28 August 2003 at 10:05 PM · edited Mon, 27 January 2025 at 12:03 AM
Look what happens to the terrain every time I
1...use the "Gaussian Edges" in the Editor
2...change the Color of the terrain in the mat. editor
then I click ok to go back to the main screen and my terrain grows back EVERY TIME????
What the F....ck
roch222
madmax_br5 ( ) posted Thu, 28 August 2003 at 10:11 PM
did you create this terrain using a dte noise filter? If so these terrains are buggy and may fritz out like this. i suggest if you create a terrain using DTE noise with the easter egg of shift-clicking on the pictures button in the terrain editor, export the image immediately after it;s creation in the terrain editor. Then load this image as a new terrain and delete the old on. Now you won;t have problems.
Roch222 ( ) posted Thu, 28 August 2003 at 11:00 PM
THanks MadMax - this is what I ended up doing, but then I cant edit anymore once its exported. also this was just a straight up terrain, no image import, but I thiink I did use noise!!, thanks roch222
