Wed, Nov 27, 10:20 PM CST
Subject: Texture question - appreciate any help
arabinowitz ( ) posted Wed, 19 July 2000 at 12:38 PM · edited Wed, 27 November 2024 at 10:04 PM
I'm trying to get the effect of a space ship that has window lights all over it. If I use a texture with yellow dots (for example) it all looks good on the side exposed tothe light, but not the part in shadow. I want to keep that shadow effect, but still have bright window spots. Is this even possible in Bryce? Thanks. Aharon
Caligula ( ) posted Wed, 19 July 2000 at 1:06 PM
You need to make sure that your ambience is set so that the yellow dots are ambient and the rest of the material isn't. Go into the deep texture editor and click on the A (for alpha) next to the part of the material that sets the yellow dots. Then go back to the regular material editor and click the dot next to the Ambience so that your material is used for this channel as well.
Hawkfyr ( ) posted Wed, 19 July 2000 at 10:15 PM
Try different mapping modes also (Object Space,parametric,etc.) Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
arabinowitz ( ) posted Wed, 19 July 2000 at 10:24 PM
Thanks. Playing with the alpha and setting it to Parametric or parametric scalled, did the trick. Thanks folks. Aharon
