Sat, Jan 11, 12:14 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: Free Prop host needed...
jetson61 ( ) posted Thu, 28 August 2003 at 6:45 PM ยท edited Fri, 10 January 2025 at 9:25 PM
Just some home-made props. Thought some may want. Need a host. let me know. Some carved directly from Mike's face/ Others were carved from the Batman mask that used to be somewhere here or at Animotions. Haven't been able to located the original.
shadowcat ( ) posted Thu, 28 August 2003 at 9:40 PM
If you carved them directly from mike's face make sure you have encoded them. Mike's mesh is copyrighted. How big is the file?
jetson61 ( ) posted Thu, 28 August 2003 at 9:45 PM
Small ...the set Zipped is less than 300 k
sturkwurk ( ) posted Fri, 29 August 2003 at 6:17 PM
Very cool, but shadowcat is exactly correct, you'll have to encode the files. Doug
I came, I rendered, I'm still broke.
jetson61 ( ) posted Fri, 29 August 2003 at 9:12 PM
what do ya meen encode?
shadowcat ( ) posted Fri, 29 August 2003 at 11:32 PM
You need to get a utility called Mover (in freestuff) this program will "lock" the .obj of your props. The key to unlock the props is the original item that you made the props from. If this is not done you cannot legally share the masks.
