Mon, Jan 27, 2:13 PM CST
Subject: Windows XP - Vue d'esprit and OPENGL
rodluc2001 ( ) posted Sat, 30 August 2003 at 3:19 PM ยท edited Mon, 27 January 2025 at 2:06 PM
Hi all, i've a problem with my new PC, after the reinstallation of vue if i use OpeGl acceleration ' can't work, because i can't see nothing but noise... if i uncheck the opengl i can use the wireframe view... can someone help me ??
Veritas777 ( ) posted Sat, 30 August 2003 at 4:26 PM
That IS your most likely option- using the wireframe view. I have a state-of-the-art OpenGL card from Radeon, and every OpenGL app works great accept Vue. So I don't use it- that will likely be what your choice is too. Fortunately, I don't mind using wireframe as I'm very used to it from previous versions of Vue, so it doesn't bother me. (I'm on Windows 2000 Pro)
sittingblue ( ) posted Sat, 30 August 2003 at 4:46 PM
Attached Link: http://www.guru3d.com/
You could try using an older video driver (for nVidia cards). I use Detonator 23.11 without any problems. Guru of 3d offers the driver as a free download.
Charles
lingrif ( ) posted Sat, 30 August 2003 at 6:07 PM
There are times when open GL really is helpful - placing things on elevated areas of landscapes, for example. So I turn it on, do what I need to do, then turn it back off again. I have an NVIDIA GeForce MX 440. If I leave Open GL on, movement starts to get jerky moving things in the scene.
www.lingriffin.com
haegerst ( ) posted Sat, 30 August 2003 at 6:28 PM
Ive tried different drivers for my matrox card, but after experimenting a bit I always ended up in turning it off... That seems the more stable and in some cases even faster option...
Vue content creator
www.renderarmy.com
rds ( ) posted Sat, 30 August 2003 at 9:33 PM
I use: Operating system: Windows XP Pro CPU (type & freq.): P4 2.4 mghz RAM & HD space: 1.00 GB of Ram 80gig HD space Video board: NVIDIA GeForce4 Ti 4200 Desktop resolution: 1024x768 Color depth: 32 bits (millions of colors) Open GL works just fine for me. Regards, shoop
gebe ( ) posted Sat, 30 August 2003 at 11:24 PM
OpenGL works fine for me too, but mostly I turn it off, because Vue is much faster without it:-) Guitta
rodluc2001 ( ) posted Sun, 31 August 2003 at 4:52 AM
10x a lot...
