Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Here are th esame results, sorted by CPU, CPU speed, result speed P= Pentium NB= Notebook (time) = overclocked CPU speed, Poser 5 SR3 render times PXeon 2x2.66Ghz 2 Gb RAM Win XP Pro - 209 seconds PXeon 2x1.7Ghz 1 Gb RAM ? 345 seconds P4 NB 3.06 Ghz 1 Gb RAM Win 2K Pro 211 seconds P4 NB 1.7Ghz 1 Gb RAM Win XP Pro 352secondss P4 3.06Ghz 1 Gb RAM, Win 2K 169 seconds P4 3Ghz 1 Gb RAM Win XP Home 176 seconds P4 3Ghz 2 Gb RAM Win XP Pro 199 seconds P4 2.8Ghz 1 Gb RAM Win XP Pro 192 seconds P4 2.8Ghz 1 Gb RAM Win 2K 194 seconds. P4 2.8Ghz 1.5 Gb RAM Win XP Home 218 seconds P4 2.8Ghz 512 Mb RAM Win XP Home - 253 seconds P4 2.53Ghz 1 Gb RAM Win XP Home 237 seconds P4 2.4Ghz 1.5 Gb RAM Win 2K Pro 226 seconds P4 2.4Ghz 1 Gb Win 2K Pro 227seconds P4 2.4Ghz 1 Gb RAM Win XP Home 236 seconds P4 2.4Ghz. 1 Gb RAM Win XP Pro 250 seconds P4 2.4Ghz 1.5 Gb RAM Win XP Home 258 seconds P4 2.2Ghz 1 Gb RAM Win XP Home 278 seconds P4 2.20Ghz 256 RAM Win XP Home 620 seconds P4 2.0Ghz 1 Gb RAM Win XP Pro 321 seconds P4 1.9Ghz 2 Gb RDRAM Win XP Pro 303 seconds P4 1.9Ghz 1.5 Gb RAM ? 310 seconds P4 1.4Ghz 1 Gb RAM - Win XP 396 seconds P3 933Mhz 512 Mb RAM Win XP Home 480 seconds P3 850Mhz 512 Mb RAM Win 98 SE 769 seconds P3 733Mhz 512 Mb RAM WIN 98 SE 1411 seconds P3 500Mhz 640 Mb RAM Win 2K 394 seconds Mac G4 1.4Ghz 1Gb RAM OS10.2.6 543 seconds Mac G4 800MHz 1.25 Gb RAM OS10.2.6 950 seconds AMD 2800+ 1 Gb RAM Win 2000 Pro 192 seconds AMD 2600+ ? ? 210 seconds AMD 2.5Ghz 1 Gb RAM Win XP Pro 241 seconds AMD 2.4Ghz 1 Gb RAM Win XP Home 242 seconds AMD 2.4Ghz 768 Mb RAM Win XP Home 264 seconds AMD 2.1Ghz 1 Gb RAM Win 2K 193 seconds AMD 2000+ 512 Mb RAM Win 2K Pro 259 seconds AMD 2000+ 512 Mb RAM Win 98 FE 865 seconds AMD 1800+ 512 Mb RAM Win XP Home 337 seconds AMD 1700+ 1 Gb RAM ? 278 seconds AMD 1.8Ghz 512 Mb RAM Win 2K Pro 308 seconds AMD 1.67Ghz 256 Mb RAM Win XP Home 600 seconds AMD 1.66Ghz 640 Mb RAM Win XP Pro 305 seconds AMD 1.4Ghz 1 Gb Win Win 2K Pro 234 seconds AMD 1.4Ghz 1 Gb RAM Win 2000 Pro 305 seconds AMD 1.4Ghz 1Gb RAM Win 2K 355 seconds AMD 1.2Ghz 1280 Mb RAM Win XP Pro 314secondss AMD 1.1Ghz 1 Gb RAM Win 2K 366 seconds
I agree with all but the last, average of 18 AMDs was 326 seconds, average of 19 Pentium 4s (throwing out the Notebooks and Xeons) was 256 seconds, 22% faster. With the Notebooks and Xeons in there it is a 260 second average, BTW, if I have the math right. It is still (probably) slightly cheaper to build a AMD computer, I expect, but I wouldn't say thay have an advantage in Poser 5 like they did in Poser 4.
You cant average with so many different speeds. 7 of the P4s are 2.53Ghz and higher. Only one AMD system is 2.5Ghz, and that is overclocked (there are no Athlon 2.5Ghz CPUs yet, the highest is the 3200+ @2.2Ghz). Something like this is a little more valid: AMD 2800+ (2.083Ghz) 1 Gb RAM Win 2000 Pro 192 seconds AMD 2.1Ghz 1 Gb RAM Win 2K 193 seconds P4 2.8Ghz 1 Gb RAM Win 2K 194 seconds. From those results, it looks like the AMD CPU is a good bit better than the P4 in Poser. It's 700-800Mhz slower yet still on top.
I don't think the results are conclusive, because not everyone was on the "same sheet of music." There were two versions of the Bench Mark -- one with P5 Hair and one with Trans-mapped hair. Most people have not stated which one they ran. Also, some people seemed to be uncertain about how to run the test. Different procedures in testing will definitely yield different results.
Poserverse The New Home
for NYGUY's Freebies
Thanks cubed!- I "lost" some of the OSs and stuff when I transposed the results, anything that wasn't in one message was lost, some other stuff was probably lost from my sheer stupidity. I only did the one Poser 5 test, the Posette has a P5 Mohawk. There was also the old, original P4 test, the one in my Free Stuff, which some ran in Poser 5, but neither test uses trans-mapped hair. nyguy- my P4 2.8 Ghz did 209 seconds originally, got it down to 194 by optimizing the memory speed in the BIOS, it was back up to 221 seconds yesterday after I installed Asus Probe (wipped that sucker right back off!). Yeah, the times do jump around a bit, first is often the best one, I used first-run on all of my results. The only vaid results are really first-run with NO changes in Poser 5. However, iyt is perfectly valid to make changes external to Poser to try and get better results! Anyway, if you look at the new thread that Mark started, with a graph of the results, it does all start to make a little sense. Hey guys, before we leave testing, how about a LOADING SPEED test? I saw one comment about "took awhile to load..."
SORTED BY SPEED P4 3.06Ghz 1 Gb RAM, Win 2K 169 seconds P4 3Ghz 1 Gb RAM Win XP Home 176 seconds P4 2.8Ghz 1 Gb RAM Win XP Pro 192 seconds AMD 2800+ 1 Gb RAM Win 2000 Pro 192 seconds AMD 2.1Ghz 1 Gb RAM Win 2K 193 seconds P4 2.8Ghz 1 Gb RAM Win 2K 194 seconds. P4 3Ghz 2 Gb RAM Win XP Pro 199 seconds PXeon 2x2.66Ghz 2 Gb RAM Win XP Pro - 209 seconds AMD 2600+ ? ? 210 seconds P4 NB 3.06 Ghz 1 Gb RAM Win 2K Pro 211 seconds P4 2.8Ghz 1.5 Gb RAM Win XP Home 218 seconds P4 2.4Ghz 1.5 Gb RAM Win 2K Pro 226 seconds P4 2.4Ghz 1 Gb Win 2K Pro 227seconds AMD 1.4Ghz 1 Gb Win Win 2K Pro 234 seconds P4 2.4Ghz 1 Gb RAM Win XP Home 236 seconds P4 2.53Ghz 1 Gb RAM Win XP Home 237 seconds AMD 2.5Ghz 1 Gb RAM Win XP Pro 241 seconds AMD 2.4Ghz 1 Gb RAM Win XP Home 242 seconds P4 2.4Ghz. 1 Gb RAM Win XP Pro 250 seconds P4 2.8Ghz 512 Mb RAM Win XP Home - 253 seconds P4 2.4Ghz 1.5 Gb RAM Win XP Home 258 seconds AMD 2000+ 512 Mb RAM Win 2K Pro 259 seconds AMD 2.4Ghz 768 Mb RAM Win XP Home 264 seconds AMD 1700+ 1 Gb RAM ? 278 seconds P4 2.2Ghz 1 Gb RAM Win XP Home 278 seconds P4 1.9Ghz 2 Gb RDRAM Win XP Pro 303 seconds AMD 1.4Ghz 1 Gb RAM Win 2000 Pro 305 seconds AMD 1.66Ghz 640 Mb RAM Win XP Pro 305 seconds AMD 1.8Ghz 512 Mb RAM Win 2K Pro 308 seconds P4 1.9Ghz 1.5 Gb RAM ? 310 seconds AMD 1.2Ghz 1280 Mb RAM Win XP Pro 314secondss P4 2.0Ghz 1 Gb RAM Win XP Pro 321 seconds AMD 1800+ 512 Mb RAM Win XP Home 337 seconds PXeon 2x1.7Ghz 1 Gb RAM ? 345 seconds P4 NB 1.7Ghz 1 Gb RAM Win XP Pro 352secondss AMD 1.4Ghz 1Gb RAM Win 2K 355 seconds AMD 1.1Ghz 1 Gb RAM Win 2K 366 seconds P3 500mhz 640 Mb RAM Win 2K 394 seconds P4 1.4Ghz 1 Gb RAM - Win XP 396 seconds P3 933mhz 512 Mb RAM Win XP Home 480 seconds Mac G4 1.4Ghz 1Gb RAM OS10.2.6 543 seconds AMD 1.67Ghz 256 Mb RAM Win XP Home 600 seconds P4 2.20Ghz 256 RAM Win XP Home 620 seconds P3 850Mhz 512 Mb RAM Win 98 SE 769 seconds AMD 2000+ 512 Mb RAM Win 98 FE 865 seconds Mac G4 800MHz 1.25 Gb RAM OS10.2.6 950 seconds P3 733Mhz 512 Mb RAM WIN 98 SE 1411 seconds
SORTED BY PROCESSOR
AMD 1.1Ghz 1 Gb RAM Win 2K 366 seconds AMD 1.2Ghz 1280 Mb RAM Win XP Pro 314secondss AMD 1.4Ghz 1 Gb Win Win 2K Pro 234 seconds AMD 1.4Ghz 1 Gb RAM Win 2000 Pro 305 seconds AMD 1.4Ghz 1Gb RAM Win 2K 355 seconds AMD 1.66Ghz 640 Mb RAM Win XP Pro 305 seconds AMD 1.67Ghz 256 Mb RAM Win XP Home 600 seconds AMD 1.8Ghz 512 Mb RAM Win 2K Pro 308 seconds AMD 1700+ 1 Gb RAM ? 278 seconds AMD 1800+ 512 Mb RAM Win XP Home 337 seconds AMD 2.1Ghz 1 Gb RAM Win 2K 193 seconds AMD 2.4Ghz 1 Gb RAM Win XP Home 242 seconds AMD 2.4Ghz 768 Mb RAM Win XP Home 264 seconds AMD 2.5Ghz 1 Gb RAM Win XP Pro 241 seconds AMD 2000+ 512 Mb RAM Win 2K Pro 259 seconds AMD 2600+ ? ? 210 seconds AMD 2800+ 1 Gb RAM Win 2000 Pro 192 seconds AMD 2000+ 512 Mb RAM Win 98 FE 865 seconds Mac G4 1.4Ghz 1Gb RAM OS10.2.6 543 seconds Mac G4 800MHz 1.25 Gb RAM OS10.2.6 950 seconds P3 733Mhz 512 Mb RAM WIN 98 SE 1411 seconds P3 500mhz 640 Mb RAM Win 2K 394 seconds P3 850Mhz 512 Mb RAM Win 98 SE 769 seconds P3 933mhz 512 Mb RAM Win XP Home 480 seconds P4 1.4Ghz 1 Gb RAM - Win XP 396 seconds P4 1.9Ghz 2 Gb RDRAM Win XP Pro 303 seconds P4 1.9Ghz 1.5 Gb RAM ? 310 seconds P4 2.0Ghz 1 Gb RAM Win XP Pro 321 seconds P4 2.20Ghz 256 RAM Win XP Home 620 seconds P4 2.2Ghz 1 Gb RAM Win XP Home 278 seconds P4 2.4Ghz 1 Gb Win 2K Pro 227seconds P4 2.4Ghz 1.5 Gb RAM Win 2K Pro 226 seconds P4 2.4Ghz 1.5 Gb RAM Win XP Home 258 seconds P4 2.4Ghz 1 Gb RAM Win XP Home 236 seconds P4 2.4Ghz. 1 Gb RAM Win XP Pro 250 seconds P4 2.53Ghz 1 Gb RAM Win XP Home 237 seconds P4 2.8Ghz 1 Gb RAM Win XP Pro 192 seconds P4 2.8Ghz 1.5 Gb RAM Win XP Home 218 seconds P4 2.8Ghz 512 Mb RAM Win XP Home - 253 seconds P4 2.8Ghz 1 Gb RAM Win 2K 194 seconds. P4 3.06Ghz 1 Gb RAM, Win 2K 169 seconds P4 3Ghz 2 Gb RAM Win XP Pro 199 seconds P4 3Ghz 1 Gb RAM Win XP Home 176 seconds P4 NB 1.7Ghz 1 Gb RAM Win XP Pro 352secondss P4 NB 3.06 Ghz 1 Gb RAM Win 2K Pro 211 seconds PXeon 2x1.7Ghz 1 Gb RAM ? 345 seconds PXeon 2x2.66Ghz 2 Gb RAM Win XP Pro - 209 seconds
I don't know any way to put this up and preserve the nice formatting (I put all the stuff in an Excel spreadsheet, but I don't have Frontpage), but here are the results sorted by pure speed: P= Pentium NB= Notebook (time) = overclocked CPU speed, Poser 5 SR3 render times P4 3.06Ghz 1 Gb RAM, Win 2K 169 seconds P4 3Ghz 1 Gb RAM Win XP Home 176 seconds AMD 2800+ 1 Gb RAM Win 2000 Pro 192 seconds P4 2.8Ghz 1 Gb RAM Win XP Pro 192 seconds AMD 2.1Ghz 1 Gb RAM Win 2K 193 seconds P4 2.8Ghz 1 Gb RAM Win 2K 194 seconds. P4 3Ghz 2 Gb RAM Win XP Pro 199 seconds PXeon 2x2.66Ghz 2 Gb RAM Win XP Pro - 209 seconds AMD 2600+ ? ? 210 seconds P4 NB 3.06 Ghz 1 Gb RAM Win 2K Pro 211 seconds P4 2.8Ghz 1.5 Gb RAM Win XP Home 218 seconds P4 2.4Ghz 1.5 Gb RAM Win 2K Pro 226 seconds P4 2.4Ghz 1 Gb Win 2K Pro 227seconds AMD 1.4Ghz 1 Gb Win Win 2K Pro 234 seconds P4 2.4Ghz 1 Gb RAM Win XP Home 236 seconds P4 2.53Ghz 1 Gb RAM Win XP Home 237 seconds AMD 2.5Ghz 1 Gb RAM Win XP Pro 241 seconds AMD 2.4Ghz 1 Gb RAM Win XP Home 242 seconds P4 2.4Ghz. 1 Gb RAM Win XP Pro 250 seconds P4 2.8Ghz 512 Mb RAM Win XP Home - 253 seconds P4 2.4Ghz 1.5 Gb RAM Win XP Home 258 seconds AMD 2000+ 512 Mb RAM Win 2K Pro 259 seconds AMD 2.4Ghz 768 Mb RAM Win XP Home 264 seconds AMD 1700+ 1 Gb RAM ? 278 seconds P4 2.2Ghz 1 Gb RAM Win XP Home 278 seconds P4 1.9Ghz 2 Gb RDRAM Win XP Pro 303 seconds AMD 1.4Ghz 1 Gb RAM Win 2000 Pro 305 seconds AMD 1.66Ghz 640 Mb RAM Win XP Pro 305 seconds AMD 1.8Ghz 512 Mb RAM Win 2K Pro 308 seconds P4 1.9Ghz 1.5 Gb RAM ? 310 seconds AMD 1.2Ghz 1280 Mb RAM Win XP Pro 314secondss P4 2.0Ghz 1 Gb RAM Win XP Pro 321 seconds AMD 1800+ 512 Mb RAM Win XP Home 337 seconds PXeon 2x1.7Ghz 1 Gb RAM ? 345 seconds P4 NB 1.7Ghz 1 Gb RAM Win XP Pro 352secondss AMD 1.4Ghz 1Gb RAM Win 2K 355 seconds AMD 1.1Ghz 1 Gb RAM Win 2K 366 seconds P3 500mhz 640 Mb RAM Win 2K 394 seconds P4 1.4Ghz 1 Gb RAM - Win XP 396 seconds P3 933mhz 512 Mb RAM Win XP Home 480 seconds Mac G4 1.4Ghz 1Gb RAM OS10.2.6 543 seconds AMD 1.67Ghz 256 Mb RAM Win XP Home 600 seconds P4 2.20Ghz 256 RAM Win XP Home 620 seconds P3 850Mhz 512 Mb RAM Win 98 SE 769 seconds AMD 2000+ 512 Mb RAM Win 98 FE 865 seconds Mac G4 800MHz 1.25 Gb RAM OS10.2.6 950 seconds
