Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
Attached Link: http://uvmapper.com/
Yes. You need to run your box through uv mapper (see link if you don't already have it) and use the 'split vertices' option. This will cure all your problems. What's happening is that Poser is trying to smooth the box and making a dog's breakfast of it. Splitting will fix this. macThanks. I looked closer at some of the established lower res models (such as the original Poser4 figures) and noticed similar dark smudges on some surfaces. It seems to be a universal aspect of Poser smoothing under unfavourable circumstances (lighting/model/camera angle, shadow map size, etc). High res models (keeping individual poly faces small) and big shadow map sizes seems to minimise the problem. That's a relief. I thought I was finally getting somewhere with 3D modelling but had a horrible feeling it was all for nothing. Back to fiddling. Thanks again.
Question. That stuff that looks like shading on the top left cube? Is this the same thing: sometimes I'll bring a model into Bryce and it shades like that..even flat surfaces. I've found that if I smooth it in Bryce (at the defaults) that weird shading goes away. (I rarely if ever import to Poser that's why I mentioned Bryce). Is what I describe the same as above? BTW..not important, just something i've been wondering about for a while and never thought to inquire about.
Seams.... hmm. I tried it just now, made a "seamy" box in Amapi and rendered in Poser 4. Sure enough, the corners are sharp enough to draw blood, but the seams themselves show up fairly clearly. Is there a minimum proportion of seam width / face width that works best?
My python page
My ShareCG freebies
Thanks for the clarification, VK. I'll have another go with seams later. By the way, the name's PJF not PFO. Not that I mind particularly but since PFO is a well known Poser acronym for "Poser Forum Online" (original name of this website and now a separate entity) it might be confusing for some. :-)
Thanks for the precision, VK. My Amapi model was about 10%, which is obviously too large. I'm experimenting now with a Python script to place seams on chosen faces "in place". Having a numerical target helps......
My python page
My ShareCG freebies
![file_73975.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_73975.jpg)
On the left is a simple OBJ box (with bevelled edges) made in a 3D program. On the right is the box prop included in Poser4. (non-rendered view on the bottom) Can someone please explain the weird render facets on the modelled box, and what might be done at the modelling stage to avoid them? The box renders fine in Bryce. I tried making a box with more polys, but just got the dark facets at a higher frequency.
