Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Hello what i do is this.. First modle the props as an individual piece, so if you have 2 pieces,export them from your modeling prog as obj. Then run them in uv mapper and save the maps and the obj, then import each piece to poser position them were you want them and them export as one obj,then bring them back intop poser and there you have one obj with both groups and materials set up so all you do is paint on the maps and apply them to the prop hoipe this helps regards seeklight
ok I have an idea...O.o but NO idea how to make it. what I need to do is to ...er...glue two figures together. but cant seem to do it so that when I bring it back into the scene they stay stuck together. I went to the grouping tool...but I just dont think it worked. and now they are siting together and I keep geting cross talk whenI bring in the final figure and it messes everything up... How do I glue...or freeze to human forms to make one unit??????
https://www.darkelegance.co.uk/
Commission Closed till 2025
