Yes. Double-click on the dial to open the Parameter Dial panel. Set your min and max values however you wish. Depending upon the dial, you might have to enable the Use Limits function from your Figure menu. Limits are usually automatically forced for morphs, but not for things like rotation or trans. Or you can hack the Poser file with a text editor to enable the forceLimits switch for that specific dial.
Here is an example of seting the limits in a translateY channel.
translateY ytran
name GetStringRes(1028,13)
initValue -0.00309944
hidden 0
forceLimits 4
min -1.500
max 1.300
trackingScale 0.001
keys
static 0
k 0 0
interpStyleLocked 0
The relevent lines are "forceLimits 4", which instructs Poser to use limits for this channel, the next two lnes (min & min) that tell Poser what the limits are.
Hi Again, Can you change the min and max values of a perimeter dial so that a yTran won't move beyond a certain point and what not? Cheers
