Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 04 8:39 am)
Try parenting it to the Chest instead of conforming then move/scale to fit. Also, a trick I use with some items (such as conforming shoes, fingernails, bracers, blah blah things with 2 separate pieces) it load in two. Place and parent Fig1 and then place and parent Fig2. Easy work-around. Still might have to jostle them around depending on posing, but it works in a pinch.
"That's another fine mess you got me in to!" -- Oliver Hardy
Panko, It looks like the top you used for the bones was set too high, or V3 wasn't in the default pose when you positioned the two collar pieces. First, try it with a different V3 top, or even with V3 itself in the setup room. If you use same V3 default you used whn you loaded the figure, it will almost have to conform perfectly. Try it and let me know how it works.
A little while ago I found a very good conforming char (by Tagame) of armpit hair for Michael 2. Trying to make it fit V3 though is no simple matter and it's a pity for this piece of work is far superior to any hair growing method I've tried in Poser 5. Any suggestions?
