Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 10:04 am)
What's happened here is that Vicki's head moved from its original position sometime during the morphing process - so that movement has become part of the morph. The movement could have occurred while getting the mesh to work with, or while it was in LightWave. For the first, I recommend using only the original mesh (from the Geometries folder) rather than an exported one. As for the second, you know more about LightWave than I do, but are there different ways of importing and exporting OBJ format? You may be able to fix it by trial and error, moving the head until the morph no longer has that effect. Or it might be easier to do it again. :)
Upgrade to LW 7.5 (support for groups) and do what EnglishBob says. Work with the actual obj file from geometries folder. Or continue to use LW 7 and make sure Vicky is TOTALLY zerod before exporting head and test the exported head as a morph to make sure it works. Vicky's hip or body probly had a translation setting when you exported.
I think it's because you have America Online running in the background. Try installing it (or deleting the "aol.exe" file) and see if that helps. This is intended as sarcasm. Even though AOL affects your browser, your e-mail, your image viewer, your OS, your newsgroup reader, and signs you up for tons of spam, it doesn't affect Poser.
