Are you actually rendering the movie, or merely outputing the display mode? Video textures only show up when rendered. Animation menu --> Make Movie --> Quality --> Current Render Settings Poser should automatically increment the frames of the video texture to be in sync with the rendered movie. Make certain the framerates match.
OoooH! OoooH! I think I know! Make sure your AVI file is saved at the speed of the animation in Poser ( normally 30 frames per second). If it's saved at say, 1 frame per second, then the first frame of your AVI texture will appear in frames 1 - 30, the second in frames 30 - 60, etc. (That's assuming Poser is set to 30 fps).
Using Poser 5 it is possible to apply an AVI file as a 2D texture in the Materials room. When I do this I can render a still image and see the first frame of the AVI file applied to my object, but when I render a Movie with multiple frames the animating texture does not animate. How is this supposed to work?
