Mon, Feb 10, 6:30 PM CST
Subject: Creating animated AVI 'movie' textures
pmoore ( ) posted Mon, 08 September 2003 at 1:41 AM ยท edited Mon, 10 February 2025 at 6:03 PM
Using Poser 5 it is possible to apply an AVI file as a 2D texture in the Materials room. When I do this I can render a still image and see the first frame of the AVI file applied to my object, but when I render a Movie with multiple frames the animating texture does not animate. How is this supposed to work?
Little_Dragon ( ) posted Mon, 08 September 2003 at 3:22 AM
Are you actually rendering the movie, or merely outputing the display mode? Video textures only show up when rendered. Animation menu --> Make Movie --> Quality --> Current Render Settings Poser should automatically increment the frames of the video texture to be in sync with the rendered movie. Make certain the framerates match.
pmoore ( ) posted Mon, 08 September 2003 at 6:21 AM
Yes, I've tried rendering the movie as an AVI file. The texture remained immobile. Is there something about the CODEC used in the AVI file that is signiicant?
smiller1 ( ) posted Mon, 08 September 2003 at 9:26 AM
OoooH! OoooH! I think I know! Make sure your AVI file is saved at the speed of the animation in Poser ( normally 30 frames per second). If it's saved at say, 1 frame per second, then the first frame of your AVI texture will appear in frames 1 - 30, the second in frames 30 - 60, etc. (That's assuming Poser is set to 30 fps).
pmoore ( ) posted Mon, 08 September 2003 at 5:32 PM
Am in Australia using PAL, so frame rate is 25 fps. This is the setting both within Poser and the AVI. Resoluiton is also the same - 720 x 576, DV quality. Any other ideas??
mateo_sancarlos ( ) posted Mon, 08 September 2003 at 5:50 PM
I doubt it will make a difference, but I would use uncompressed video for both the texture and the final movie. It might be too hard for Poser to decode and then re-encode a texture movie.
pmoore ( ) posted Tue, 09 September 2003 at 1:57 AM
Will try with uncompressed - at least for the texture. But that can make for a pretty big video file. I just wish Poser could compress using the DV CODEC on the system.It doesn't seem to recognise it.
