Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 4:32 am)
Do you mean you're trying to load "All Head Morphs" or "All Body Morphs" and your system gets hung up? If so, you may not have the resources to do this...my husband sat and waited for over an hour and they never loaded. It took my system about 2 minutes total to load all head and all body morphs. As far as what to do...not quite sure...never had this problem...you may have to load each individual set seperately.
I couldn't even load them individually! lol Now I don't know what to do :o(
Poser 9 SR3 Â and 8 sr3
Processor Type:Â AMD Phenom II 830 Quad-Core
Hard Drive Size:Â 1TB
Processor - Clock Speed:Â 2.8 GHz
Operating System:Â Windows 7 Home Premium 64-bitÂ
Graphics Type:Â ATI Radeon HD 4200
•ATI Radeon HD 4200 integrated graphicsÂ
System Ram:Â 8GBÂ
Yes, I let it go wherever it was suppose to , didn't change anything.
System Ram:Â 8GBÂ
If you have more than one version of Poser installed, make sure you've installed it to the version you're using him in. I had this problem with V3, when I tried to install her in Poser 4 but use her in Poser 5. Copying the !DAZ folder over to Poser 5 fixed the problem; I'm now able to inject the morphs in Poser 4 and 5.
I have poser 4 and 5, I have V3 and all the daz stuff in P4 so that is where I put M3
System Ram:Â 8GBÂ
Ok I uninstalled him and reinstalled, I was trying to inject them using P5 so I will try in P4, Thanks Deecy I never thought of that! And thanks everyone I will let you know if it works ( boy do I feel silly! lol)
System Ram:Â 8GBÂ
Deecy I did what you said, and they loaded instantly! lol So I just saved him with all the morphs ;o) Thanks!
System Ram:Â 8GBÂ
randym77 is right on the money. It all comes down to the !Daz folder. You can go ahead and install in the P4 structure, then either copy only the !Daz folder to the P5 library structure and everything should work fine. This drive me crazy with V3. This time I knew better. I installed in P4, moved the !Daz folder, and everything works great. Punomaus has a great idea too. I never thought of using the multiple Runtime option to set up a seperate library structure for each major character. I may have to restructure all my files this weekend.
Thanks I will copy the !Daz folder to P5 also ;o)
System Ram:Â 8GBÂ
This is such a common problem. I'm surprised they haven't addressed it with their installer. The installer already detects all the copies of Poser you have on your machine. Seems like it would be relatively simple to have the installer copy the !DAZ folder to all of them, or ask you if you want it done. I mean, since P5 can read any runtime, while P4 can only use its own, it seems logical to install stuff to the P4 runtime, if you're using both programs. I imagine a lot of people do it that way. Then wonder why it takes so long to inject the morphs.
randym77 - Agree, but it's a competitor's product, which Daz has been on record as not supporting. shadowblade - any idea why your system should behave differently (better) in this respect than others? You're not the only one to report this, but it certainly seems to be only a small percentage that don't experience the hang in Poser 5. Did you get a later edition of Poser 5 that came on a CD with some or all of the SR's already installed, for example? Do you mind sharing your version number for Poser 5 (Help > About Poser), the latest version # via patching is v5.0.2 .281, do you have a later one? Or if your's is significantly earlier, it'd mean that the bug (feature) was introduced by an SR...
Okay, guess I'm an idiot... I still don't get them to work at all... I've been thinking about reinstalling p5 anyway, so will give that a shot. I reinstalled m3 letting it go where it wanted, but none of the inj poses work. Only have p5 on. Wonder how much of a hassle this is going to be? oh well... deletes and cringes.
Someone else want to verify this: For P5 only: Place the !DAZ folder in the primary Library only. The INJ poses will work from any remote Runtime - there does not need to be a copy of !DAZ anywhere but in the main Runtime. For Poser 4, there will still need to be a copy of !DAZ in this Library if you wish to use both programs. It looks like the maximum number of copies of !DAZ you will need is 2 and this is only if you are still using both P4 and P5. If you are only using P5 then just one copy is necessary, and the character injections can still be scattered through multiple satellite Runtimes.
Ok, since Daz is obviously not supporting Poser 5 beyond bsre necessities, let me get this straight. Can I install M3 into his own runtime and then Move his !Daz files into my main Poser 5 Runtime folder for this??? Can I do the same for V3? I am going to be reinstalling Poser 5 and 4PP on my new computer and need to know this. Little problem for his morph packs as they are all !files. Hmmm, wonder if that also applies to the Rdna Inj stuff for Macrocosm and LaRoo??? Emily
The same for the RDNA stuff too. Same principle. If you have both P4 and P5 have a copy of the !DAZ folder in each's basic runtime. That's all you have to worry about. Doesn't seem to matter what runtime you have the inj poses in as long as the !DAZ folder is in the basic runtime for P4 AND P5. Just remember to install updates to BOTH !DAZ folders!
The reason that P5 takes so long to inject V3/M3 morphs when eventhing is in a remote Runtime is probably because it is looking in the main Runtime no matter where the pose file with the readScript path is. The readScript must be working at a basic level of the coding, since it is outside the cross-talk protection level too.
You should put the !Daz folder in Poser5-Runtime-Libraries, the M3 and V3 (latest updates) inj/rem poses can then be run from any runtime/folder structure of your choice. Some third party inj poses wich make calls to the Daz pz2 inj in poses will stop working if the !V3 or (presumably) !M3 folders are moved out of the root of poses in the P5 runtime, but they can be fixed by editting the files to make calls to the !Daz folders directly. -- Mark
Mark
I tried all last night, but I can't get them to work, anyone having this problem or know what might be wrong? Thanks
System Ram:Â 8GBÂ
