Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 1:47 am)
Pardon me for digging out an old thread, but I have a question about this. When you open a p4 model that has a transparency map applied, P5 creates a node called transparency_map, and not image_map. Is there any difference between an image_map node applied to the transparency plugs, or a P4 converted transparency_map? I can't seem to find any way (short of hacking the cr2) to make a transparency_map node. Is this just a quirk of using old stuff? I can't seem to ever get transparencies to work in poser 5 when I try to apply them from scratch. Am I missing something?
I think I have it working - Apparently there's no way to create a node called "transparency_map", but image_map seems to have the same settings, and, other than weirdness when I try to use a tif as a texture, it seems to work. I kind of miss the simple one-page materials dialog in P4. Sure, you can do lots more with the new setup, but it takes a lot longer to 'wire' everything up.
Okay so I finaly did my own transparency map only to find out that I don't know where to put it. I'm working with Poser 5 and I don't know where to link the map in the material room. I really need some help here, please....
