Wed, Nov 13, 4:44 AM CST
Forum Moderators: Wolfenshire, Deenamic Forum Coordinators: Anim8dtoon
Photoshop F.A.Q (Last Updated: 2024 Nov 04 10:41 pm)
Are you up to the challenge??
Subject: Circular Text
josiahpugh ( ) posted Mon, 24 July 2000 at 1:57 PM · edited Wed, 13 November 2024 at 4:39 AM
How do you make circular text in Photoshop?? I want text that is on an arc. Thanks.
Spanfarkle ( ) posted Mon, 24 July 2000 at 3:31 PM
About the only way I think you might be able to do it is to manually position every individual letter. Type in Photoshop won't follow a path. If you have Illustrator you can import it into Photoshop.
pam ( ) posted Mon, 24 July 2000 at 5:16 PM
it is not too hard to do it in ps... 1-make a dot on a layer, to use as your arc center. 2-Put each letter on it's own layer, and click on the layer in the layers pallet, but do not select the letter. 3-go to Edit>Transform>Rotate A rectangular box with a center point will show around the letter. Take the center mark, witch is your rotation center, and place it over the dot you made earlier, then rotate the letter around it's new hub. 4-Do that with each of your letters till you are done!
adam ( ) posted Mon, 24 July 2000 at 7:37 PM
Do you have Microsoft Word? It is SO easy if you do it in Word and drag the text onto photoshop. I do that all the time.
josiahpugh ( ) posted Mon, 24 July 2000 at 8:50 PM
How do I do this in Illustrator then? I have Illustrator, and I have Word, but I would prefer Illustrator. Thanks.
adam ( ) posted Mon, 24 July 2000 at 9:24 PM
Well, just in case you want to use Word, this is how you do it: -click the 3D looking "A" at the bottom of the window that says "WordArt" when you more your cursor over it -then select what you want -when you finish typing in the words and style, drag the finished text into Photoshop and that's it Adam
Spanfarkle ( ) posted Tue, 25 July 2000 at 9:53 AM
I would save as a Illustrator EPS, then open in Photoshop. Or else just cut and paste.
bradthedog ( ) posted Tue, 25 July 2000 at 2:17 PM
yes if someone can best explain this using illustrator 8 I would appreciate it. I have access to it, but not really familiar with it.
harold_u ( ) posted Wed, 26 July 2000 at 1:35 AM
to create circular text in illustratro, just use the circle tool to make a circle (just the stroke, no fill in the circle), next go to the type tool, and if you hold it down you will see that it has different type styles(just like the photoshop version does, but more), choose the one with the wavy line and the "T" on top of it. That's the type tool to make type follow a path. Next click on the circle and you should see the blinkind bean, and just start typing. If you don't like the position of the type, just simply use the move tool(which is the top left button on the tool bar) and just use it to move it along the curve. You can then save it as a pic, and open it in photoshop....one thing I haven't tried is coping the type once it's done and pasting it to photoshop....try it.
Spanfarkle ( ) posted Wed, 26 July 2000 at 10:45 AM
You can also save as a Photoshop 5 file in Illustrator.Works great.
josiahpugh ( ) posted Wed, 26 July 2000 at 1:33 PM
Thank you so much. This will work great on my new web site!
Darth_Logice ( ) posted Sat, 12 August 2000 at 12:05 PM
There is a way to do it totally in photoshop. do a search for either my name on this forum or for circular text. It is outlined there, it's easy, and good results. -Darth_Logice
