Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 13 3:34 pm)
If you are feeling brave open PoserRuntimeprefsPoser.ini in a text editor I have the following lines in mine:- ANIM_PALETTE_LOC 189 384 ANIM_PALETTE_ON 0 ANIM_PALETTE_SIZE 800 353 Back up the Poser.ini, Poser.exe and Poser.rsr files just incase, and ensure that Poser is closed before you alter the file. Legal disclamers..... dont do it!!! on your own head be it!!!! I told you nuffin!!! :) but that's what I would do if it had hapened to me. Good luck PhilC
I have the dumbest problem that I can not solve no how. I openned the animation palette from the Windows toolbar. While I was repositioning it I moved the title block off the poser work area. Now I can't find a handle on the animation pallete to allowing repositioning of the pallete. I've tried exiting poser and then coming back in. When I turn the animation pallete back on the pallete is displayed with the header block off the poser work area. Any Ideas??
