One thing that might work is if you duplicate a cube that is in your booleaned group then resize and position where the window should be. If the duplicated cube is a member of the booleaned group it should do the boolean operation when turned to negative. I haven't actually tried this myself but it sounds logical so give it a try it may solve hours of reworking it. 8) Catlin
Catlin: I think the problem is that a duplicated member of a group does not duplicate the relationship with the group, just the object.
Thanks Catlin, Oh, and I figured out why my lighting looked so bad, it wasn't the sky ambiance, it was in the little tiny candles in each window. The strength is only 10, but I bumped up th eshadow anbiance to about 7 and voila, glowing white house...LOL Took it back down to 0 and I have color again!
I'm sure there's a much easier way than this, but if there doesn't turn out to be, maybe you could open a copy of bryce with the default sky and export it to a preset sky file, then exit and load your bryce scene and then import that preset sky file? Haven't tried it myself. Not sure what things are included with that export. Supposedly to reset sky & fog pallette settings you can just click on the memory dot in the upper lefthand corner. However that doesn't appear to reset things like the sun position for instance, so I don't know if that would work for you depending on what you might have changed.
