Tue, Feb 11, 1:14 AM CST
Subject: Quality of Vue Pro Exports to Poser 5?
regaltwo ( ) posted Tue, 16 September 2003 at 5:18 PM ยท edited Tue, 11 February 2025 at 1:02 AM
I would appreciate it if somebody who's bought Vue Pro could post a rendered image of a scene they've exported from Vue into Poser 5, so that we can judge the quality. Quite frankly, the thing I most want to be able to do is take Vue into Poser so I can make use of the cloth and hair rooms. But if the resulting scenes are low quality, I see no reason to spend the money. Anybody that can help with this, thanks!
sirkrite ( ) posted Tue, 16 September 2003 at 6:39 PM
The exports of scenes are only for. *Synchronization plug-ins and file format support for 3DS Max, Cinema 4D, LightWave, Maya, Softimage XSI... That's how it looks to me. I don't think Poser 5 is concidered a Major 3D application. I may be wrong.
sacada ( ) posted Tue, 16 September 2003 at 7:38 PM
Poser allows 3ds import, so it should be able to import a Vue Pro 3ds export.
Gloubi ( ) posted Tue, 16 September 2003 at 10:52 PM
I don't see the interest to export to poser....
gebe ( ) posted Wed, 17 September 2003 at 12:29 AM
OK, I have just created a quick one. This is a Papyrus plant, exported as it and imported into Poser. Guitta
gebe ( ) posted Wed, 17 September 2003 at 12:34 AM
When exporting from Vue to Poser, you can select a resolution. The above plant (to make it faster) were exported in a very low resolution.
Guitta
smallspace ( ) posted Wed, 17 September 2003 at 12:48 AM
"...I don't see the interest to export to poser..." Since Poser 5's Dynamic cloth and hair only work in Poser, then it desirable to be able to import a scene into Poser to access those features. -SMT
gebe ( ) posted Wed, 17 September 2003 at 2:02 AM
Oh sorry, something I have to say: I imported the above plant into Poser 4. I have Poser 5 but I'm unable to use it for the moment, I only had a short look to it and have to learn every thing about. So, I will ask to another beta tester to try it and then give you the answer. This may take several days. I think sirkrite is right concerning entire scenes, but plants and terrains works fine in Poser 4... Let's see for Poser 5.
gebe ( ) posted Wed, 17 September 2003 at 9:10 AM
OK, I have already the answer: Pro doesn't import entire scenes into Poser. Poser is not a high end application. But you always can import terrains and any plant, as well into Poser 4 as into Poser 5.
Quoll ( ) posted Wed, 17 September 2003 at 11:46 AM
Don't forget that you can render in each program and then composite the results. There are still a lot of opportunities.
