LithUnwrap can convert .3ds files to .obj and other formats. It's also a mapping application similar to UVMapper. I actually use both utilities, depending upon what I need to accomplish.
Attached Link: http://home.europa.com/~keithr/Crossroads/index.html
Crossroads will convert then you can add a UV map with UVMapperActually Deecey's solution is the best and easiest :o) Poser vcan do that easily. AND it won't mess up the scale :o)
Provided it is Not a single mesh, then in Anim8or I would give the diffent groups their own names, then Export as obj and use UVMapper to assign materials. If however it is a single mesh then all Anim8or is good for is exporting it out as obj. For this sinario Poser would probably be better Provided the 3ds has materials assigned to begin with.
I'm looking for a freeware program / application to convert .3ds files to .obj files to texture them in UV Mapper.
