Wed, Jan 8, 10:17 PM CST
Subject: Clothifying Two Figures
Amadan ( ) posted Sat, 20 September 2003 at 8:07 PM ยท edited Wed, 08 January 2025 at 10:11 PM
Using Poser 5. I have two figures in the same scene, both wearing dynamic clothing. Following HMann's excellent free tutorial on dynamic clothing, I have discovered that while I can clothify both clothing items, they can only be set to collide against the same set of objects/figures. Changing the figure against which one item of clothing will collide also sets the other clothing item to collide against the same figure. When I render, one item of clothing will drape correctly, but the other one goes sailing off to try to "collide" with the other figure.
Frame 1: Zeroed poses
Frame 5: Final pose
Is there any way to put two figures with dynamically draped clothing in the same scene?
Thanks,
-David
Little_Dragon ( ) posted Sat, 20 September 2003 at 8:31 PM
Hmmm. Perhaps it would work better if you created a separate simulation for each clothing item? Then you could have different collision targets for each clothing item, although it would take longer to set up as you'd have to calculate each simulation separately.
PhilC ( ) posted Sat, 20 September 2003 at 8:34 PM
Have you tried creating a separate simulation for each piece of clothing? A scene may include more than one simulation.
Little_Dragon ( ) posted Sat, 20 September 2003 at 9:06 PM
It does appear to work. Took quite a while to drape and calculate both sims, however.
jerr3d ( ) posted Sun, 21 September 2003 at 12:53 AM
Your animation looks great Little Dragon! Does someone have the link for the above mentioned HMann's tutorial? thanks!
Little_Dragon ( ) posted Sun, 21 September 2003 at 5:18 AM
It's available in .pdf format at Poserfashion.
jerr3d ( ) posted Sun, 21 September 2003 at 8:25 AM
Thanks Little Dragon
